Electronics arrived today :)
Glued the back wing and shaped the foam for the rudder ( Is there any other way to mount the servo rather than gluing it to the foam?)
Installed the motor , which is a turnigy 35-42B 1250Kv, mount needs some hot glue
Then the ailerons , all servos are the 1800A
That's all for now , if u have any advice or comments please let me know:)
Here you go:
The rudder servo horn is a bit low, and will probably get stripped eventually, but the elevator is way up out of the way of the ground.
original packing instruction put the servos on the tail boom with lazer cut plywood mounts.
But havent decided if thats good or bad as of yet.
"Is there any other way to mount the servo rather than gluing it to the foam?"
Since it's mounted in foam, hot glue is probably the best.
I have used pipe cleaners before, but you would end up tearing the foam in this case.
