100KM
Aerial mapping stitch by MS ICE
3689537758?profile=original
Recently Lianpin Koh suggest to me to try out the Microsoft ICE. It is an advanced panoramic image stitcher. The best part : It's a freeware.
Being just completed to map 20000 Ha of oil palm land for a local plantation, I have huge data set on hand to try out if it is suitable for general use. This is a pure images stitching program, so the end result is not geo reference.
The result is simply amazing. I just load all the images and wait for the program to finish the work. No editing or intervention what so ever. Depends on the number of images, my i5 8GB ram notebook take 15 to 20 minutes to finish a 350 images data set. I'm very impress with the stitching quality, the final image looks like it was taken by a single shot.
I do encounter some problem with area cover by thick tropical rain forest. MS ICE had difficulty to stitch those images and most of the time it just ignore it and leaving the area empty. I think this is a common problem for all UAV base photogrammetry program.
The total area of this mission is about 250 Ha. The above image show smaller area because I have crop it. My Skywalker base UAV take about 30 minutes to cover the whole mission at 300 M altitude. The ground sampling distance is about 11 cm per pixel.
For those of you who just need an aerial photo of a big area, I think MC ICE can do a good job especially if the images contain many features. APM and Mission Planner is a real winning combination for aerial mapping. The system is robust and reliable. Give it a try, I'm sure you'll not disappointed.
  • 100KM
    Hi Mauro
    I'm using Canon S100 GPS with CHDK install. here is my UAV set up and you can have more info here. Visit the hardware and software section.
    Just post here if you need further info. Wish you success in your mission.
  • I have been using ICE with success. Paired with my inexpensive (hundred dollar) HD UAS, it has allowed me the opportunity to get some impressive shots for cheap. Check out my blog about it...
    http://www.diydrones.com/m/blogpost?id=705844%3ABlogPost%3A1330059
  • 100KM
    Hi Martin, Thanks for the feed back. I have a closer look at the stitch result. It is true that there are misalignment in some area. It is not perfect yet. To me the error is small and acceptable consider it is a freeware.
    I also think that the error may be due to the images input. Since the camera is attach directly to UAV, not on a  stabilized mount, some images are not taken at vertical angle. This may contribute to the stitching error.
  • That's a hell of an area keeyen. Well done!
  • I tried MS ICE a long time ago, dont know if the program is better now, but the image you put in the post is not so good, lots of errors, you can see roads duplicated or trimmed.
  • 100KM
    Thanks Gerard. Good info. I'm currently using cloud service for geo ref orthomosaic. I'm more on the fly drone and take aerial image. Those post processing job will be out source. But ultimately your info will help me to understand the idea of geo ref image and their work flow. Thanks again
  • Keeyen,
    You can georeference any image with opensource GDAL tools. They work something like this:
    gdal_translate -of GTiff -gcp 0 0 -82.5586187839508 35.59414007259327 -gcp 0 410 -82.55858659744263 35.5937998255945 -gcp 520 0 -82.55741715431213 35.594340730401775 -gcp 520 410 -82.55728840827942 35.5940266570877  test.jpg test_temp.tif
    TIFF is typically used, because this can contain the Georeferenced info (geotiff). It is recommended to have 5 control points in a reasonable distribution and these do not need to be corners. If you do not have GPS info for pictures, I'd use a bit more. I'd go with natural marks in your case, so you don't have to go back and recollect stuff. The preparation is going to take a bit more time though.
    If you're looking at point clouds, try VisualSfM in combination with CMPMVS. These require windows with 16G memory and an Nvidia card, but the results are astounding and quite precise. You can then use the resulting .ply file in Meshlab for further analysis (volume?), especially if you used GCP, because then the units mean something.
  • 100KM
    Hi Grant, ICE is just a stitching program. For geo ref orthomosaic, DEM or DSM, you'll need program like pix4d to do the job.
  • 100KM
    Hi Wieliang, It take three weeks for us to map the whole area. Each mission flight cover 200 to 300 Ha depends on location. As you may know, landing area is very limited in plantation.
    No the stitch is not good enough, the very nature of stitches is that stuff gets sacrificed and things stretched.
