The new ArduPilotMega Shield "Hotel' Version 1.0 has finally replaced our old and problematic Foxtrap 2.2, many of the changes are just to accelerate the assembly process and reduce production failure rates, working in conjunction with the very supportive
Invensense Team (Thanks guys!).
Note: if you are a user with the current boards, they're fine. The problems were in the production process, which required us to go through extra steps to ensure they passed QA. The new board is more for our sake than yours!
Manufacture changes:
-Improved gyro pads.
-The boards now came with Lead-Free Silver Immersion for an even surface (Turns goldy when baked).
-Added one 0603 resistor pad on voltage divider for automatic machine placement. I should have added it to all the resistors. =/
User Experience:
-Now that is easy to assemble, boards availability will be improved.
-Solder jumpers to optionally enable/disable gyro low pass filters.
-Added labels that suggest where the female headers should be placed.
Bugs fixed:
-Reset button now works under any condition.
-Analog supply for the pressure sensor is now attached to the analog 3.3 voltage regulator.
By the time I wrote this post I still had some
Oilpan in stock, please hurry because we are moving to a new warehouse and we may be out for around one week again, just in time to start production with our new
Japanese made Manncorp 7722V. Many thanks to the Mancorp team that is also located next to us in San Diego,CA!
Eagle Files:
ArduPilotMegaShield_H_v10.brd
ArduPilotMegaShield_H_v10.sch
Also many thanks to Star Wars (TM)!
