I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning, can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
Hi, i just got the minimosd from hk and it looks like it doesnt come with the bootloader installed.
Is this usbasp ok to install the bootloader?
http://www.banggood.com/USBasp-USBISP-3_3V-Or-5V-AVR-Downloader-Pro...
Thanks for the help
Sure, but have to check connection, as you only need 6 pins.
Use jumper wires ;)
Gábor
Is it possible to display the channel 6 tuning value such as declination?
Hi steve,
Do you want to see ch6 raw value?
Yes raw value should be ok.
can flight summary be added to the OSD. after landing it should display the max dist etc?
Sure.
It is addedlong time ago. ;)
Just use the latest.
Gábor
thank you for the prompt reply
i also wanted to know if better and faster OSD is possible for APM?
please check the discussion here: http://diydrones.com/forum/topics/better-and-faster-osd-for-apm
thanks
Well,
Font can be changed to whatever size U want.
There is no problem with speed. It is very fast.
Update rate is up to APM, so it is not the OSD.
On thing i agree. The graphical part.
Gábor
what is needed to improve the graphics?, the APM has nothing to do with it IMO.
how i understand is that apm is simply sending telemetry data rest is the OSD's job.
