Adding extra functions to MinimOSD
I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning,  can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
        • Hi Xian06,
          You're welcome. Let me know if/how you fix it :)
          Miguel
  • Hi Swift,
    I think it have been already answered there:
    The easiest way is to use telemetry and get the mavlink message.
    Checking out the minimosd source code is a good starting point.
    Miguel
  • Why do not switch panels?
    I tried direct mode on ch6 and ch8 with and without rotate but do not swith.
    RSSI allway 0% and show Warning VSPEED  but on the desk.
    • Did you disable the auto-panel switch in case of a warning? See here: http://www.rcgroups.com/forums/showthread.php?t=2021896&page=29...
      • Splinter...
        As you can see, "Auto Panel Switch" is disabled. The only way I can get the OSD to not freeze after arming the APM is to disable the "Warnings" , but it totally defeats the purpose.
        3702653401?profile=original
    If you have problem to update the charsets with your MiniOSD i've found that, with the latest plane version (R780) is impossible to update the charsets, just flash before the latest copter version (R789), flash the charsets 2.4.0.1 and then reflash the plane hex.
    • Copter 2.2 Freezes after arming APM...anyone know what the issue is and how to fix it?
      • Hi Pyr8,
        Freezing is a known issue of copter 2.2.
        It freezes after 1 minute poweres on.
        Please try the latest pre-release r791
        Miguel
        • Thanks for the reply Miguel!
          I have tried r791, but the issue is that the character-set does not take. The "Heading Rose" is a bunch of Gobeldy Goop (random characters), as well, the AS & GS characters are incorrect. What do you suggest I do to get the character-set working with r791?
          (please provide a link to the set you are using)
          • Hi Pyr8,
            You should be able to upload the latest charset (MinimOSD_2.4.0.1.mcm) with the latest CT Tool (r788)
            The charset is inside the CT Tool folder.
            Miguel
