Adding servo to aux channel 1 - How do I do it?!
I've been stuck on this for a while. How do you set up a spare channel to run a servo through the aux outputs?
This is what I have tried:
Go to APM planner > Initial setup icon > Optional setup > Camera gimbal
Then assign 'Tilt' to RC9 and set input channel to, say, Ch7 which I have spare.
I am told elsewhere the RC9 outputs to output 1 on the pixhawk (also know as pin 50 apparently)
[If all this is true, why would you make RC9=Output 1=Pin 50! Why not have just one descriptor of the same thing?]
So if I have all that correct then all I need to do is stick my server into connection 1. Then I need to add a 5v power supply to any of the other pins 2-6. All being well I can then control something through the output?
I have tried this but think I'm missing something. Any help would be greatly appreciated. :)
  • Admin
    @Jamie,
    Have you read this portion of the Wiki concerning the Pixhawk Aux analog output channels Link ?
    TCIII AVD
    • Thanks. I'm returing to this after a break. I'll take a look. cheers.
