Airspeed preflight Calibration with Android device
I just started using a Nexus 7 tablet in a GCS.
The problem is that neither Droidplanner nor Andropilot  have any way of doing a preflight calibration for airspeed.
Does anybody know how to do this?
Is there a work around to achieve airspeed calibration until it is added to one of the android apps?
Thanks,
Rob
  • Hi Andre,
    I have done ARSPD_AUTOCAL and that is fine. I am referring to preflight calibration like found in Mission Planner.
    When the APM is first plugged in the airspeed is always at a high level even with the plane motionless.
    The preflight calibration brings it close to 0.
    • strange, it might be due to the fact I run a little older Arduplane.  -still, do not know why something needs to be done manually.
  • There's no need to do it often.
    For calibration; disable ARSPD_USE
    You can achieve very good calibration by enabling ARSPD_AUTOCAL  , then disable it when you are happy with the results , enable ARSPD_USE
