Hi all,
I'm getting readings from airpressure and airspeed sensor that are somewhat unstable.
It happens when board powered up through USB only, BEC only, and through USB + BEC.
readings from the sensors jump from 0 to 10m/s (airspeed) and from -0.3 to 1 (altitude)
Is this behavior normal? If not - how can i fix it?
This is a screen cap of test/airspeed first, then test/airpressure second (you may need to watch it in 480p for data to be readable):
Plane is stable and away from vents, fans, etc.
Sensor is pmxv7002dp
Thanks!
  • i took a voltmeter and connected it to power at the telemetry port: https://www.youtube.com/watch?v=U-wb5So6WE0 - voltage jumping between 4.97 and 5.07 - thats a clue!
    Unplugged Ublox gps unit - rock solid at 5.23, airpseed became solid too.
    Will try to power up GPS unit separately from APM.
