Altitude hold tuning
Hello, I own an APM 2.6 flight controller. Really cool piece of technology. I have it flying pretty well, IMO. Only thing im curious about tweaking, and a bit apprehensive, is altitude hold tuning. Altitude hold mode works mostly perfectly, except when I fly forward fast. It looses altitude with high speed. Is this normal? is this something I need to tune? If so how do i go about tuning altitude hold? or are there other solutions?
Thanks, Nate
Btw im using 3.1 fw,
  • Hi Nathaniel did you solve this problem ?
    i have the same issue
  • It's possible you're hitting the max performance available from your power system.  Can you do the same thing in stabilize mode without losing altitude?
  • Reduce max allowed pitch/roll. You are most likely getting to an angle where there's too little downward thrust left..
