Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
Hi
A bunch of things will be broken with the current codebases available with 3.3. I don't think there's the need of doing anything while 3.3 is not final. As an example, between RC1 and RC2/3 a new flight mode (17-STOP) has been implemented, so IMHO is better to wait....
luis
Hi
this one is for IVALE
i used your lua script from github
and i got some strange telemetry screen on taranis
whats wrong
i want to see this screen
and also i cant see any gps data on screen only battery that connected to pixhawk
did i do something wrong ?
by the way under model name i have two telemetry files
teleme1 & teleme2
thank you for your work
Hi
Thanks for looking into that.
Strangely I see a mixup on the branches, which I don't understand, because I haven't touched github for quite some time.
I just re-downloaded the zip file From GitHub and apparently on the zip file things are ok.
please re-download the zip file linked above and ONLY keep the required files on the SD card on the radio, i.e. only telem1.lua on the model name dir.
Guess I have to go and recheck the github repo :)
Luis Vale
ok
i worked with this file : lvale-MavLink_FrSkySPort-1.4-79-gd8649b9
its not the same ?
No idea what that is
I just went to the github page (https://github.com/lvale/MavLink_FrSkySPort) and clicked download zip
OK i just re-downloaded now it looks good
but i can see only battery status on screen no compass and gps data show on taranis
ohh and i always get warning sound "mismatch flight switch"
the only thing i changed when flashed teensy 3.1 is number of cells :
Cell ( Voltage of Cell=Cells/6. [V])
i also get blinking CALC near 35 % battery
by the way on mission planer gps data exist.
maybe A firmware upgrade on X8R ?
From this thread previous page:
I don't know how you might have your teensy connected but sometimes the telemetry values might not be conveniently sent, if on a different serial port. There are a bunch of parameters that control how the values are being sent on that serial (telemetry) port. There is a screen on Mission Planner that forces the sending of parameters when using a MinimOSD, that you can try to use to force sending the Mavlink data.
Currently I do have a minimOSD connected in parallel with the Teensy, and both work fine.
The parameters I was referring on the APM code are the SRx (where x is a specific COM port) parameters
the parameters are something like this
One good way to check this would require putting the Teensy in Parallel with a telemetry radio, using only the RX input on the Teensy, then checking via a standard telemetry radio connection to Mission Planner and as the Teensy is receiving the same data as being sent via the radio, that should work.
Hi
the tested versions on the radio are 2.0.15 and on the PixHawk 3.2 and 3.2.1
The CALC indication is because the script has not enough data to estimate remaining flight time. It assumes you have correctly set the battery parameters on the PixHawk, via Mission Planner.
No changes are required on the Teensy sketch.
The parameters that are user configurable are on the script, to match the flight modes, as described on the script itself (lines 36 to 47).
If the flight mode set on the PixHawk is different from what the switches on the radio have, then the flight switch mismatch is played. It can also happen when the PixHawk enters a Failsafe condition and goes to RTL or Land, while the switches are probably on Stabilize.
And the flight number is on this list a little below
Hello,
I read most of this thread in the attempt to resolve the issue I have with telemetry on Taranis with Teensy, but still have it working only partially.
The hardware part seems to be OK - soldering is ok. I cut the link for power on the back of Teensy, as suggested. Using Telem 2 port on Fixhawk.
The Teensy is running the code (led is rapidly blinking - almost solid orange).
Lua scripts loaded in Taranis and I'm getting Headline, GPS status, Alt and some other metrics, but left side of the screen is all zeroes - no voltages from battery.
Is there a way to check where the problem is? Can I actually see what's coming to Teensy and what it outputs?
Thanks in advance. This is great community.
Check out Wolke's reply to me on page 82. Hope this links to it. http://diydrones.com/forum/topics/amp-to-frsky-x8r-sport-converter?...
You need to run the script with serial port logging and then you can what the values are being read on each analog pin. Good luck. And check the analog inputs with a multimeter to make sure there is a sensible voltage.
