Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
Really, that's good news.
What is the file name for the new PPM encode FW, I could not see it on your file page just now ??
Martin
hi,
after some work on teensy code and lua scripts i will share my first version here. it is available at https://github.com/wolkstein/MavLink_FrSkySPort default branch is s-c-l-v-rc. changes on teensy code are located in MavLink_FrSkySPort and Taranis Lua scripts and sounds are located in Lua_Telemetry.
The main focus of this script and teensy modification is the exact monitoring of the flight battery capacity, voltage and cell status. The consumption in mA / h and watt-hours can be calibrated on a separate model script.
the script need no special settings on taranis to work. flightmodes will displayed on lcd&&Audio Message by reported flight mode from mavlink.
the radar on the left side works different to other heading arrows. the arrow can move around to display the position relative to home. and it can rotate to display the heading relative to home.
this mod works with opentx >=2.0.12. tested up to nightly builds 2.0.13 http://jenkins.open-tx.org/nightly-20/11_15_2014/
greetings and hopefully this is usefully
wolke
simulator screen shot. values are incorrect.
teensy mod:
Como instalo ESO en mi taranis, ya hise lo de las resitencias para mi 3S Pero lo del la radio no se como hacerlo, me sale la misma pantalla de antes con unas pocas modificaciones. Copie las Carpetas Que subio en la SD, sin ver la lipo en la radio logro mi.
Great job !
I have installed it on my taranis, but I would remove the single_cell fonctions as I will not make the teensy mod whith the resistors : will it be enough to comment the line 87 in MavLink_FrSkySPort.ino :
// #define USE_SINGLE_CELL_MONITOR ?
And I don't understand how to get the battery capacity in Wh ? I have a lipo 4S 5000 mAH...how many Wh sould it deliver ?
Last question : in the teensy mod schematic it is write "not connect the lipo-balancer gnd-line to the teensy board directly", but it's also write "this both GND must be the same" : so they must be connected ?
Thanks,
Ed
you must comment line 87 and 88 in MavLink_FrSkySPort.ino
did your charger told you how many wh was chared into the battery. my charger give me this information.
you have three choices to get Wh infos of your battery.
GND
there a main reasons to leave the gnd line from lipo cell connector to teensy open. if you use two lipos in serial it can happens that you disconnect the main plug on the negativ side first. and if your ballancer plugs already connected to teensy in this case all current flow through this gnd line and through the whole electronic. the gnd line is not saved with an fuse.
in my case this happens and peace of luck i only burn the teensy board and not my apm.
the teensy board get gnd from receiver which mostly is connected to apm/pixhawk. the gnd from lipo ballancer only is connected to the resistor network ground resisters. this make sure that no high current can flow to teensy. but if you also connect gnd from ballancer plug to teensy this dangerous loop is closed and an high amount of current can flow through the teensy and other electronic.
Thanks for your answerd.
Great job again !
Are the values important? I dont have any 1k2 resistors atm but 1k1, would those do?
Or just big enough difference is important so they would work then? :)
important is only that voltage divider set teensy A0-An input voltage never higher than 3.3V. also you have to change/recalculate the dividers in https://github.com/wolkstein/MavLink_FrSkySPort/blob/s-c-l-v-rc/Mav... line 194-199.
/g
wolke
Ahh ok, I get it! =)
Im using a 3S lipo, can I just skip a few resistors then, or does the code need modifications too?
yes, you only need voltage dividers for s1-s3 and teensy inputs A0-A2. so you can reduce the network to six resistors, and if you want, you can set "#define MAXCELLS 6" to "#define MAXCELLS 3" in https://github.com/wolkstein/MavLink_FrSkySPort/blob/s-c-l-v-rc/Mav... line 91.
/g
wolke
