Any good airframe plans out there!!
Hi all, when I used to fly rc aircraft as a kid there was an abundance of good plans available, in the UK there used to be th RCM+E plans handbook with hundreds available, nowadays it all seems to be ARTF or RTF stuff, does anyone know of any plans for good airframes out there for something suitable for vertical photography, preferably something fairly big and stable??
  • Hi guys:
    I have this motor:
    [B][I]Turnigy Aerodrive SK3 - 2836-2500kv Brushless Outrunner Motor.[/I][/B]
    Specs:
    Turns: 6T
    Voltage: 2~3S Lipoly
    RPM/V: 2500kv
    Internal resistance: 0.02 Ohm
    Max Loading: 35A
    Max Power: 405W
    Shaft Dia: 3.175mm
    Bolt holes: 16mm & 19mm
    Bolt thread: M3
    Weight: 80g
    Motor Plug: 3.5mm Bullet Connector
    TURNIGY TRUST 45A SBEC Brushless Speed Controller
    Rhino 2250mAh 3S 11.1v 25C Lipoly Pack
    What I need? :
    stable under high gust wind.
    slow airframe for Aerial Photo, and Sonar Applications.
    space for 2 cam, sonar, ardu and miscellanies .
    High lift.
    Please answer base in this power system, Need your experience guys!!
    Thanks a lot.
    ps.Sorry abt my english !!!
    There are hundreds of plans still out there. Once people get serious they soon move away from RTF Although bang for buck its hard to beat a Blixer for simple photography. Have a ferret around here http://www.modelflying.co.uk/
  • Here is one. Only problem is to get those wing profiles.
    http://diydrones.com/profiles/blogs/taigacam-robust-plane-for
    3692329921?profile=original
