APM 2.5 doesn't power up
I am connecting the battery as usual and the APM 2.5 is not lighting up. I got home and started disconnecting everything from it and finally it worked. I checked the DF13 6 position connector (voltage regulator) and it seems to be ok. Has anybody had problems with this connector? The cable seems to be firmly attached to the power regulator and the APM... I don't have a reason to distrust it.
Thanks guys!
    Hi Estebanflyer,
    I'm assuming your using a 3DR Power Module correct? Can you confirm the 3DR PM is putting out voltage at the DF13 connector?
    Have you tried powering the APM board via an UBEC or ESC w/BEC without the 3DR PM?
    Nathaniel ~KD2DEY
