APM Dedicated BEC
Hey guys,Question regarding power and brownouts.I am using a regulated dedicated BEC to power my APM. My question is is this enough to STOP brownouts ? I am not powering any servo, just APM 2.6 and receiver.I am really trying to prevent brownouts. The power module is not an option.Thanks in advance
  • Question for you guys!  Not sure where to ask this but I have a 2.6 apm/gps/compass/osd/telem....  I also use the apm 5.v power module.  I noticed since I added the osd I have brownout that ends in a flip of death!  I have read others having the same issue with random parts with all these items plugged in. By adding the osd does it max out the bec or something like this?
    I tried another osd unit and same thing.  But when not plugged in it's fine.
    I took the telemetry unit off left the osd plugged in and worked fine as well!
    My next step is just to add a bec and power the osd on it's own.  My last ditch effort to fix my problem. I noticed there is a diode added on my 2.6 board not found in eagle files everyone is always showing!  Everyone calls it a mistery part....  But it's not it's a diode and I'm leaning toward this part being the cause!
  • Yes. Just make sure it's < 6V and can provide at least 1 amp.
    As long as the normal "only use 80% of battery amps" rule is adhered to.
