APM2.5 goes full throttle -> crash
Hi
i'm faly new in this forum
i know, i know.... new on the forum and goes asking for help... but i woud really apreciate it!!
I crashed twice my home-made Quadcopter, using a APM 2.5, both times i was flying stabilize, at low altitude, about 2m (6.5 feet) when suddenly the throttle went 100%, and the quad started rising for some secconds. then it went back to stabilize (my fault, i wasent able to react the correct way to safe it)
any one has any suggestion what is going on?
Setup in the seccond crash:
Apm 2.5 in  stabilize mode
filesafe set to Land
turnigy er9x with a FrSky djt modeule
APM powerd with the ESC (s-bec)
    Your accelerometer offsets seems fully wrong. Did you do the accelerometer calibration ?
    http://copter.ardupilot.com/wiki/configuration/
    Your VCC voltage is a bit high, about 5.3V instead of the nominal 5.0V. Is it a 3DR board ?
    Olivier
  • T3
    I'm not sure. Can you post some logs? Also you can try connecting with USB, battery and radio and then let it sit for a few minutes, don't arm it. Then check your logs. I believe the radio info is in the Tlogs. Look to see if you radio is spiking the throttle. It's a problem I had with my Spektrum radio.
