ArduCopter 2.5 released!
Version 2.5 of the ArduCopter code is now available in the AP Mission Planner and in the downloads area!
Enhancements:
  1. The first ArduCopter code release optimized for the APM 2.  Leans and drift should be much reduced or even eliminated for most users.  This was accomplished through a number of core improvements to the DCM implementation by Tridge like this one and this one.
  2. Loiter and waypoint following should be improved due to a D term bug fix, some tuning and the improved DCM performance mentioned above.
  3. On start-up, the yaw heading is updated with first successful mag read (so you should no longer see the slow rotation from north to your actual heading).
  4. Increased output rate to ESCs to 490hz.  This update rate is also user selectable using the new RC_SPEED parameter.
  5. hexa copter stability patch bug fix (should resolve slight flattening when pitching forward and accelerating very rapidly).
  6. improved baro filtering
  7. fix to dataflash logging of Mag heading
  8. addition of H1 swash plate type and bug fix for proactive yaw compensation for collective pitch changes for TradHelis.
Tuning:
The default PIDs are optimized for a 3DR/Jdrones quad with 850 motors and 10" props. If you're using more powerful motors/props, start by turning down Rate Roll P in 25% steps.
While some testers have reported very good flights with the default PIDs, some have reported that this release is a little "sharper" due to the DCM improvements and have found they needed to:
     reduce stabilize P by 10% (i.e. 4.5 -> 4.2)
     reduce stabilize D by 30% (i.e. 0.15 -> 0.10)
     increase rate D from 0 to 0.001
Tuning loiter can be tricky.  Refer to the discussions which will appear below for more community feedback on what parameters work best.
Please post your feedback in this discussion.  For enhancement requests  and bug report, please add them to the arducopter issues list.  When possible please include logs (tlog and/or dataflash) and tell us whether you're using APM1 or APM2 and what version of the software you're using (presumably 2.5 but tell us anyway!).
Thanks for this release go to the developers (both in the core team but also those who have provided bug fixes through the issues list) and also the community members who participated in the previous release thread and provided some great detailed information in the form of issue reports and logs which allowed us to nail some bugs!
    Great.  As Mentioned on the MPU6000 scaling issue thread, I've just pushed 2.5.5 out to the mission planner and it's also available in the downloads area.
    Now, back to working on 2.6...
    ArduCopter V2.5.5ß on the download area:
    A patch release which has the following improvements over 2.5.4:
    1. MPU600 accelerometer scaling fix (affected 3dr APM2s shipped from early May)
    2. "Retro Loiter" by Adam Rivera (uses ground speed directly from GPS instead of calculating from lon/lat position)
    3. "AutoApproach" function by Marco Robustini, developed by Adam Rivera
    No other improvements to flight dynamics and auto function such Loiter/RTL/Auto in this release.
    Bests, Marco
  • 2.5.4 for Y6 ?
    I am upgrading from a quad to a Y6 but there is no 2.5.4 firmware. What’s the deal with Y6 support?
  • Which sonar is better to use with APM1.4?
    https://store.diydrones.com/MB1260_XL_MaxSonar_EZL0_p/ac-0004-16.htm
    http://store.diydrones.com/MB1200_XL_MaxSonar_EZ0_p/ac-0004-15.htm
    It seems the beam patterns and W output are the same so what advantage does the 1260 have over the 1200?
  • It must just be me... I have had 2 crashes of two different Tri-copter over the last week...
    Both crashed the same way...   Bank right ~40 but when try to return to level, the craft goes to 80-90 deg, then crashes..
    I would attach the tlog but the xbee was destroyed in another crash weeks ago..
    I fly every day and about once a week I shoot video or pictures as part of my side job....
    First crash... AMP 1.0 with 2.5.4...
    Second crash AMP 2.0 with 2.5.4
    3692414559?profile=original
    in this fig... red line is my input (roll)...   Green is attitude measued by AMP2.... all seem correct to me.... ...
    For most of the flight.. hard turns and banks.. they are very close... like it should be...
    but at the end... they diverge and the tri.. crashes...
    new 2 x 5000 mah batteries...motor logging was not on...
    I know there is not enough info here for someone to tell me what happen...  but I can't fly anymore...
    Here is link to it flying properly
    https://www.youtube.com/watch?v=ET1NbSOKS0U
    Eddie Weeks
    www.jetlens.com
    2012-05-09 17-02 153.log
  • Hi guys,
    I was almost done for the day when a friend showed up at the field with his Harpoon II with it's 90mm jet, I just couldn't resist, I only had one full battery left. Just had to try to "chase" it. It ended beeing a slow follow up and down the runway, but cool anyway ;-)
    It would have been better with less wind....
    here's a short video: https://www.youtube.com/watch?v=arl3I2X8RGk
  • Is it possible to compile with AVR studio? (New to this environment)..
  • There is evidence of redundancy with my octo Arducopter, first flying with 8 engines, then with 7 and then with 6, the strange movements are the result of my stupidity and not attributable to the plate, I must say that flew much better in the I did test before burning, I could nervousness jejejee the camera .... the video is up.
    Sorry for my English, translated with google.
    http://youtu.be/dzRhOUsoJ9w
  • What’s the easiest way to have waypoints to show up when I play back a mission? I am learning how to use the mission planner and have not found the correct button to push.
  • Yesterday upgraded my APM1 to 2.5.4 software and made some flights. At first i made some little PID tuning, so my quad flys almost perfect.
    When i began to test and tune alt hold/loiter modes (low altitude at first), motor on one side suddenly stopped just after switching from loiter to alt hold. My quad was real lucky - made one 360 deg. flip and fall on landing gear without damage.
    After this accident, i checked all cables and connections (really i have only one connection - from ESC to APM, all other are soldered), and made some more flights. But next time i meet same problem (switching loiter -> alt hold = stop motor = spins = crash) at higher altitude (10m). This time crash destroyed 4 props, 2 motors, battery (it made a lot of smoke around).
    What can it be? Now i'm afraid to meet this problem again and cant understand reason of this... Please, help me. Thanks!
    p.s. In flight log, crash happens at 53% (time 23:02)
    2012-05-05 22-58-19.tlog
