ArduCopter 2.7.1 will become available on Mission Planner and in the downloads area shortly. This release contains a few important bug fixes as well as the first implementation of the MPU6000 sensor-fusion code.
Detailed changes are in the commit log. Here's a summary:
New:
- Preliminary support for MPU6000 on board sensor-fusion (DMP)
- AP_Limits: Experimental "bounce" mode, for smaller spaces (LIM_RECMODE)
Bugs:
- Bug fix for yaw error buildup on takeoff
- Fix in Auto mode for failsafe handling
- Fixes to 3-axis camera gimbal code
I loaded the 2.7.1 HIL firmware on my APM 2.0 for testing with FlightGear. However, I could not connect to the APM from the Mission Planner. I reloaded the Hexa firmware and verified that I could connect. Then re-loaded the HIL firmware to verify that I still could not connect to it with this firmware loaded. Any ideas?
Thanks for posting, and for all of the hard work Andreas, as well as all of the developers. I have a few questions regarding Limits (i.e. GeoFence) I love the idea of bounce mode. Can I enable/disable it with a switch - let's say channel 8? Also, can I abort an RTL after a fence breach by momentarily turning off limits and then right back on again? My thought was to do this with a mix of the enable switch and another momentary switch on the radio, and of course on the enable channel 7.
Most GeoFence parameters seem to be either grayed-out or ineffective in the GUI in the mission planner since it's V1.2 release. Is it my installation or is this a real bug?
hi all.
Small test v2.7.1 apm 1.4, sonar lv ez 4, frame xaircraft 650v4 motor 850 xaircraft, 10x4.5 xaircraft , 1.350 grams, plush 10amp esc, lipo 2650
quad octo testing soon
default pid no wind.
mode stabilizes. excellent very stable orientation.
2012-08-02 18-04-50.tlog
APM1. Camera gimbal is not working. The Pitch and Roll axes not correctly work.
So what is meant by "sensor-fusion"?
How do I implement crosstrack, is it CLI only? It is grayed out on the config screen.
Does this address the wobble in loiter mode...........Don
Very Cool I will try to test this afternoon
Thanks, Andreas! It's in the Mission Planner now.
