ACRO bug (fixed in 2.9.1b): while doing flips in ACRO mode, if you switch to Stabilize while inverted your throttle will go to minimum. To regain throttle control you need to switch back to ACRO then back to Stabilize again (i.e. switch to stabilize twice). You never lose control of roll/pitch/yaw.
Loiter/AltHold/Auto/RTL bug: if you switch into these modes with throttle at zero motors will go to minimum until you raise the throttle.
Auto mode altitude bug (fixed in 2.9.1b): setting a waypoint altitude greater than 320m over home altitude may wrap around and instead be interpreted as a low altitude.
ArduCopter 2.9 is now in the mission planner and the downloads area!
The major improvement is we use inertial navigation to improve altitude hold. This increased reliance on the accelerometers means you must do some additional set-up before flying:
1. Perform the new accelerometer calibration in the mission planner (video). The auto-trim metho has also changed (video).
2. Add vibration dampening foam between your frame and the APM. Some suggested materials: DuBro, gel, hk foam.
3. If upgrading from 2.8.1, modify the throttle and altitude PID values:
- Increase your Throttle Rate P, reduce I to zero, increase D
- Increase Altitude Hold P, reduce I to zero
- Tune Throttle Accel P and I terms but try to keep P about 1/2 the size of I
Here is the list of major changes (a more detailed list can be found in the release notes):
- Alt hold using inertial navigation (Leonard, Randy, Jonathan)
- AUTO_VELZ_MIN, AUTO_VELZ_MAX parameters control the max climb/descent rate for the autopilot (cm/s)
- PILOT_VELZ_MAX controls max climb/descent rate for the pilot (in cm/s)
- Landing improvements (Leonard/Randy). Copter will descend to 10m or until an object is sensed with the sonar. Then slows to 50cm/s descent (speed can be adjusted with LAND_SPEED parameter). (video).
- Surface tracking with sonar (Randy/Leonard). Copter will attempt to maintain current distance from objects in front of sonar regardless of altitude. Only used in alt-hold and loiter, not used for missions. Sonar can be enabled/disabled with CH7 switch. (video)
- Failsafe improvements (Randy/Craig/John Arne Birkeland) including bug fixes, additional check for PPM encoder failure and implementation of battery failsafe. Set-up instructions are here.
- Mediatek gps driver accuracy improvements and use of SBAS [Craig]. Instructions on upgrading your mediatek to firmware 1.9 are here.
- Traditional Heli improvements (Rob) including (a) bringing heli code back into the fold, (b) enabled rate controller (previously only used angle controllers). (c) fix to rotor speed controllers - now operates by switching off channel 8. (d) allow wider collective pitch range in acro and alt hold modes vs stabilize mode (e) bug fix to allow collective pitch to use the entire range of servos
- Acro trainer (Leonard). Copter will return to be generally upright if you release the sticks in acro mode.
- ACRO_TRAINER : set to 1 to enable the auto-bring-upright feature
- ACRO_BAL_ROLL, ACRO_BAL_PITCH : controls rate at which roll returns to level
- Camera control improvements (Randy/Sandro Benigno): (a) AP_Relay enabled for APM2 (b) Trigger camera with CH7 or DO_DIGICAM_CONTROL command (c) Allow pilot override of yaw during missions and fixed CONDITIONAL_YAW command.
- PPM sum support for transmitters with as few as 5 channels (Randy/Tridge/John Arne Birkeland).
- Performance and memory useage improvements (Tridge).
As per usual PIDs are optimised for the 3DR/jDrones quad with 850 motors and 10" props. If you're using more powerful motors/props and are seeing bad flight behaviour in stabilize, start by turning down Rate Roll P in 25% steps.
Special thanks to our testing team lead Marco and the dedicated bunch on the 2.8.1 release thread who put their copters at risk while testing the pre-release version. Some of their videos are here: 1 2 3 4 5 6 7 8
Please feel free to report issues you find in the discussion below and/or add them to the issues list.
Hey,
There is an know unresolved issue to be able to play Vimeo videos in Windows/IE10. Is there a way you could publish your videos on Youtube or some other universally accessible video streaming service ?
thx,
Accelerometer calibration needs to be done everytime or just once???
Great Video, great 2.9, :-)))
lots of thanks to all who made this happen!!!
Let’s go flying, can’t, mad Southerly blowing :-(
I can build and upload 2.9-rc5 no problem. However, when I then try to load the released 2.9 via mission planner, the radio calibration does not work in that it will not refresh values from the transmitter. Going back to the rc5 build works fine again. I have tried various permutations of erasing and resetting from the CLI but no luck. Is there something here I am missing?
I can't find the parameter that sets the loiter radius.
Just uploaded this to my tricopter...
Can't wait to give this a try. Whoop Whoop!
Thank you to everyone who was involve with this release, to Marco for making all of the test videos, and most importantly to Randy for replying to all of my newbie questions...
Merci à l'équipe pour le travail:
Randy,Dave,Marco.....
Trop de mauvais temps,pluie verglas, neige pour tester 2.9 sur mon APM 1.4,Mais je suis vraiment dans l'attente..!
question: je compte actualiser mon équipement dois-je investir dans APM 2.5 ou Attendre encore un peu pour PX4 ????
Merci et encore Bravo
Loaded 2.9 / I went through the calibration process with my quad . (880kv motors / APM2 / Ublox GPS / Sonar / ) Rate roll P set to 0.100
I had the APM set to disable the arming until there is GPS lock. I armed and flew. It was foggy and snow on the ground.
Got it up to around 7m alt, and flicked it into alt hold on its way up. It immediately dropped like a brick. I managed to put it into stab mode, raise the throttle to save it from a very hard landing. Is this something I have done ?
So far seems stable - the only prob I have is under sonar, alt hold works fine the first time it engages, but then as the flight goes on it starts to rise in spurts and keeps going up. Sometimes if I disarm and rearm it settles down but then starts it after a minute or two. I have the log wit RAW, seems like vibration not a prob. The sonar is very reliable under 2.81.
I tried lowering Throttle Accel P and I and Alt hold P down - still about the same. Is some term winding up as it goes on?
2013-01-18 11-42 2.log
