Hey, I had a little brainstorm last night after watching the DJI Wookong video. It's a sweet little system, but I wondered if AC2 could do that? So I put a battery on the end of one arm and it couldn't hold level. It came close but 3-4° error meant that it couldn't fly perfectly still. So during the ride in to work I thought of a way to rework the controller so it replicates my hand on the stick rather the the PI>PI rate controller we have now.
I've never been happy with the Outer I term. It never really seemed to be very effective. I started thinking that my hand is putting a constant bias to the stick to get the perfect stability, so I could easily replicate that with the outer loop's I-term. I re-routed the Integral to directly sum with the rate controller output. I flew it tonight and it does work. I can hold perfectly level with a 22003S battery dangling from the arm. I think this is exactly what is needed for better Hexa/Octa redundancy.
Enclosed is the patch that works with 2.0.54. Just replace attitude.pde with the linked file. Then set your STB_PIT_I and STB_RLL_I to .1, and your limit to something high like 30° or 40°
Let me know how it goes for you and please let me know how you might improve it.
Jason
I have tested this now, must say I really am impressed by what you can in a short time! The only thing is that logs seems not to work
2011-12-01 12-03 2.log
Do you think this will help stability in gusty wind conditions? I don't feel I have ever achieved good stability when flying in winds that are gusting from 0 to 10mph in my garden, despite a lot of time tuning. I tried tying a string to one arm that I could get hold of and pull to simulate wind and that showed that disturbances to the 'copter caused more instability than when I disturbed the sticks.
Peter
Hello Jason, I'm looking at the new code. I see you add a stabilize_roll2 and stabilize_pitch2 but I don't see where it is use.
When I search the stab_roll (or pitch) I found it is used in the arducopter.pde file. Is something missing? Or roll2 and pitch2 are the old stuff?
Just found it. What I assume, roll2 and pictch2 are the backup stuff. :-)
Will make the test after eating. Keep posted.
Nice work Bro!
I'm going to test it now on my "big octo", need to kicking or just fly? :P
Best
I have praised DJI's properties but know that ardupilot is close to a similar solution. It is fast in the turns here:) I wonder if 054 will be able to properly display sonar log and the opportunity to test the sonar in the CLI if I reinstall it now. Is the version which is available now ready for use. I can not wait to try this battery test on the HEXA and will give you feedback
This is kinda genius. Best. Commute. Ever.
Here's my config.h just to make sure you see the correct parameters.
Also note you can set stabilize KI to tune with CH6 for dynamic in-air tuning. I picked .1 out of thin air, but slower or faster values may change performance regarding overshoot.
in the cli:
setup] tune 2
This will enable tuning between 0 and .3
test] tune
Will output the current value.
Also note, you can now enter CLI at startup by hitting enter 3 times in the serial window at reboot.
Jason
config.h
1
2
3
of 3 Next
