ArduCopter-3.0.1 released!
Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
3691038784?profile=original
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
  • After, I had change Motors from T-Motor MT4008 600kv to MN 3110-26 470 kv is very stable and temp max about 43 C only. And I still flight with 3.1-rc5  is no have Problem it.
  • Hello!
    Yesterday I'm flying with the v.3.1RC4 on my quad. Stabilize works well, but Alt-Hold and any other "automatic mode" like Loiter or RTL is problematic. The main problem is rather strange motor behavior.
    I had the same problem wrote in: http://diydrones.com/forum/topics/apm-2-6-3-1-rc2-octocopter-alt-ho...
    Also, my GPS3D fix lost and recover continuously... but I was in a elevated point where the GPS have 11 satellites!
    Anybody knows how to fix this problems?
  • HI Developers of MP --- Where would I place feature issues?
    *** Sorry about a missing problem 3 above. I posted then deleted because it sort of worked and I thought I'd not address it at this time.
    Here is a screen capture which shows crowded HUD text on the MP 1.2.85 and a new field with no indication of use?
    Below also see a long standing issue I had posted with no resolution regarding the updating and viewing of Telemetry.
    3692870037?profile=original
    Thanks for your diligent work!
    Brian.
  • Features?
    Voice Battery Voltage announcement when connected to USB.
    Is it possible to have MP planner automatigically toggle between disabling Battery Voltage announcements when on USB working when no USB connection but, a battery is connected for flight?
  • With latest MP 1.2.85    1.1.5409.36165
    Three (2) Issues/Problems -
    1) Mission Planner Map Error message on start.   Update MP 1.2.85   build 1.1.5049.36165
    Description (Repeating):
    Start up error message is: "Map change failed. try zomming out first." The error instructs to: "try zomming out first." --- I zoomed out. This did not self correct the problem and this error repeats on each MP initiation. Also, the map will not zoom to last zoom level as previously but now zooms out - to N.A. in my case.
    This upgrade has already crashed once with error - Windows 8.
    2) No Heatbeat detected. After MP upgrade the APM USB connection fails. (Repeatable but will connect once in a great while Sporadic).
    Description:
    Mission Planner 1.2.85 1.1.5049.36165 did have one successful connection after the initial automated upgrade but, on subsequent connection attempts the MP fails out indicting no heart beat detected. Note: While writing this report after several minutes of APM connection to USB and no connection to MP I tried again and the connection worked. I had tried several times prior and rebooting the MP with no success. After connection and HUD functioned I disconnected the USB and tried to re-initiate connection between the APM and MP with no success again.
    Repeatability:
    The MP initiates connections by reseting the APM and then times out with the error message that it can not get a heartbeat. Upon which the MP stops connecting to the APM. The APM restarts and comes to a normal stable LED condition of GPS lock, Blue LED solid, and the Arm/Disarm (external in my case) Red LED blinking. The Tx is bound to the Rx on the APM and connects. I am able to Arm and Disarm the APM from the Tx. Note: I can not flight test - My copter is apart.
    ****   Question: How do I downgrade to MP 1.2.84?
    Thanks.
    Has anyone been flying this new firmware on a Pixhawk unit? C'mon release them already!
  • Man this is getting deep and frustrating to find my own posts! And the lack of a topic search is, well, why?  Can we branch off into and RC5/v3.1 version of this?  Just curious.
  • I've noticed my compass heading when connected via the USB cable is about 10-15degs different from when I'm powering the APM from a flight pack and connecting via telemetry.  Is this normal?
  • Well I just ordered a new 3DR APM 2.6. Hopefully this will work for me.  Oh - also pulled the trigger on an Iris!
  • Is the new MP release buggy for anyone else?
    I just opened up MP, it asked me if I wanted to update, I clicked yes, it updated (1.2.85), then problems started. It says "Map change failed. try zomming out first." every time I startup now. Connecing to my APM fails now. Most of the time when I hit connect, the LEDs on my APM go out, connection fails, and after I close the timeout dialog the LEDs turn back on. I can still get it to connect by letting connection fail first, then hitting connect again as soon as my APM lights start to flash again. It consistently connects to the terminal (CLI) still, but the GPS test seems to crash.
