ArduCopter 3.0 is ready for widespread use. To make the transition easier, this time we are asking people to voluntarily upgrade from 2.9.1b for the next month or so before we make 3.0 the default firmware downloaded by the mission planner. The new version can be found in the Mission Planner's Beta firmware's link, firmware.diydrones.com, GitHub and the new Downloads Area.
Warning #1: A bug was found in the FENCE in which if you lost GPS it could lean at extreme angles as it tried to maintain an invalid position. This is fixed in AC3.0.1-rc1.
Warning #2: This release has not been fully tested on Traditional Helicopters
Warning #3: GPS glitches can cause sudden and aggressive position changes while in loiter mode. You may wish to reduce the WPNAV_ACCEL to 100 and Loiter PID to 0.2 (from 1.0) to reduce aggressiveness.
- Inertial Navigation for Loiter and Auto meaning much more accurate control (Randy,Leonard,JonathanC)
- 3D navigation controller follows straight lines in all dimensions between waypoints (Leonard,Randy)
- "compassmot" to compensate for interference on compass from the pdb, motors, ESCs and battery. (Randy,JonathanC) (Set-up video here)
- Safety improvements:
- simple Tin Can shaped Geo Fence
- pre-arm checks to ensure all calibration has been performed before arming (can be disabled by setting ARMING_CHECK to zero). (video description here)
- GPS failsafe - switches to LAND if GPS is lost for 5 seconds
- stability patch improvements to stop rapid climbs in very overpowered or overtuned copters
- Circle mode improvements including "panorama" when CIRCLE_RADIUS set to zero (Randy,Leonard)
- SONAR_GAIN parameter added to allow better tuning of sonar surface tracking
- CH8 auxiliary switch (same features as CH7)
- works on PX4 (some minor features still not available) (Tridge,PatH)
How to upgrade:
1. Make sure you are using Mission Planner 1.2.59 or newer.
http://ardupilot.com/downloads/?did=63
2. Click on the MissionPlanner's Firmware screen and click the "Beta Firmwares" link on the bottom right. The version numbers should update to "ArduCopter-3.0.1rc2", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults. The modified PID values for the 3dr frame can be seen in the image below.
4. If you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware.
http://copter.ardupilot.com/wiki/common-ppm-encoder/
http://copter.ardupilot.com/wiki/common-ppm-encoder-apm2x-atmega32u2/
Special Thanks to Marco, DaveC and the rest of the beta testers for putting their copters at risk during the extended testing period. Some of their videos can be found here, here, here, here, here and here. Thanks also to MichaelO for the MP changes required for this release.
All feedback welcome. Please put your questions, comments (good and bad!) below.
Added by Craig:
Please watch Randy's videos on setting up and flying APM-Copter 3.0 before you go flying. They are excellent!
Hi. As of right now, there are 114 pages and 1367 replies to this thread. Getting overwhelming and hard to follow. Was wondering if there was any chance a new Arducopter 3.0 Category could be created so that individual issues could have their own separate post? May be easier to navigate and find info?
Just curious.
When will AC3.0.1-rc2 be available to be tested?
great,
how will rest of us (80% I believe) with apm2.0 use external mag ?
First build (by newbie)
COMPASSMOT down to 4%
(AC3.0.1-rc1), 3DR PM, external compass.
Look at pictures for more info.
Almost went back to 2.9.1.
3DR Hex
880kv motors
10 x 4.7apc props
APM 2.5+
Decided on Wednesday to make the move to version 3.0.1 rc1 and that was the start of the problems.
compassmot gave me a reading of 174% which I got down to 24% by twisting the wires from the battery to the PDB and speed controllers, Instead of routing the motor wiring through the arms and back to the speed controller they now run direct from motor to speed controller via the bottom of the arms finally moved APM to the second level as per Randy's video.
This all caused another problem although the GPS was getting a lock according to the kmz file was jumping around by 10 to 20m on in some cases. I assumed that was caused by some sort of interference off the APM which was directly below. The GPS module is now on a 30mm standoff at he back corner of the top plate.
Still some file tuning to do but the Hexcopter is a lot better.
Hopes this helps someone
David Ardis
Maiden flight today with the V3.0.1-rc1. I opened gas to take off and, suddenly, the quad has turned on itself and crashed to the ground upside down. The quad has not gotten off the ground. The shift was immediate.
I've tried twice. The first time, the quad turned backwards, the second forward.
I have to say that so far my jalopy has flown always very good. Of course, I checked the propellers (I have not left any of them backwards after the compassmot procedure), reviewed the rotation direction of the motors, etc.
I hope someone has time to review my "flight" logs
Thanks.
2013-07-07 16-20 1.log
2013-07-07 16-20 2.log
Every time I update the new software version on my APM, I want to know what are the default PID settings, but If I execute the reset option, then ALL the values are reseted, including Gyro, accel, and so on.
Question: Is there any way to load only the default PID values of any version? If not, could be considered this option for future versions of the MP? (something like a "DEFAULT PID" button in Arducopter Pids screen)
I apologize if my reasoning is too obvious, but so far I have not understood very well this topic.... If I understand correctly, the ppm encoder recognises a signal loss, so that the throttle failsafe can be triggered, regardless of whether the tx/rx combo you are using offers the failsafe options or not. In other words: Failsafe option is a purely software feature, and can always be activated, regardless of the used hardware (Tx and Rx). Right?
I've always had RTL on my main mode switch which is a 3 position switch combined with a mix switch to get 6 modes. Now I'm thinking to put RTL on a dedicated switch like ch7 or ch8 but I'm wondering how it would work. A couple of examples I can think of:
You are in alt-hold mode or any other auto mode and then RTL via ch7 or ch8 but then before it completes the RTL, switch it back off. Will it go back to the auto mode that the 3*2 position switch is in?
What if you change the 3*2 position switch during the RTL? Does it interrupt the RTL? If I switch off the ch7 RTL in that case does it go back to the current mode or the one prior to the switch?
Apologies to all those people who's logs I haven't been able to look at over the past few days. I'm on vacation so I've fallen behind a little bit and there's a couple of small issues that Leonard and I are trying to sort out before we push out 3.0.1-rc2 and hopefully the final release to the mission planner. The issues in case you're wondering are:
1. make the red arming light double flash when your APM fails the pre-arm checks (done!)
2. smoothing out the nav controller's outputs so that SimonK ESCs don't wobble while in Loiter
1
2
3
4
5
of 14 Next
