ArduCopter-3.0 ready for wider use
ArduCopter 3.0 is ready for widespread use.  To make the transition easier, this time we are asking people to voluntarily upgrade from 2.9.1b for the next month or so before we make 3.0 the default firmware downloaded by the mission planner.  The new version can be found in the Mission Planner's Beta firmware's link, firmware.diydrones.com, GitHub and the new Downloads Area.
Warning #1: A bug was found in the FENCE in which if you lost GPS it could lean at extreme angles as it tried to maintain an invalid position.  This is fixed in AC3.0.1-rc1.
Warning #2: This release has not been fully tested on Traditional Helicopters
Warning #3: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the WPNAV_ACCEL to 100 and Loiter PID to 0.2 (from 1.0) to reduce aggressiveness.
  • Safety improvements:
How to upgrade:
1. Make sure you are using Mission Planner 1.2.59 or newer.
http://ardupilot.com/downloads/?did=63
2. Click on the MissionPlanner's Firmware screen and click the "Beta Firmwares" link on the bottom right.  The version numbers should update to "ArduCopter-3.0.1rc2", then click the appropriate frame icon and it should upgrade as per usual.
3691031698?profile=original3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3dr frame can be seen in the image below.
3691032069?profile=original
3691032034?profile=original
4. If you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware.
http://copter.ardupilot.com/wiki/common-ppm-encoder/
http://copter.ardupilot.com/wiki/common-ppm-encoder-apm2x-atmega32u2/
Special Thanks to MarcoDaveC and the rest of the beta testers for putting their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Added by Craig:
Please watch Randy's videos on setting up and flying APM-Copter 3.0 before you go flying.  They are excellent!
3DR Quad Set-Up Suggestions        http://www.youtube.com/watch?v=33Tl_rjhQEE
AC 3.0 "Live" Compass Calibration  http://www.youtube.com/watch?v=DmsueBS0J3E
AC 3.0 CompassMot Setup                http://www.youtube.com/watch?v=0vZoPZjqMI4
AC 3.0 Pre-Arm Checks                      http://www.youtube.com/watch?v=gZ3H2eLmStI
AC 3.0 Fence                                         https://www.youtube.com/watch?v=HDnGdo54o-4
AC 3.0 Maiden Flight Checks             http://www.youtube.com/watch?v=NOQPrTdrQJM
  • Is there any way to get the correct date and time from the log files GPS Data.
    PS Great work with 3.0.1 rc2 update got it installed this evening and tested with no issues
    Patch for the vibrations during Loiter (with reflashed ESC and other):
    I have tried now the new fix of Leonard (thanks mate) for this know problem, now vibrations completely disappeared during Loiter.
    This great fix will be available in the next release.
    Bests, Marco
    Leonard and I have just pushed 3.0.1-rc2 into the downloads areaGitHub and it will also appear shortly in the mission planner's Beta firmwares area.
    The changes are mostly small bug fixes but we've also reduced the Loiter Pos P to 0.2 and you may notice that your loiter is not quite as tight as before but we'd like people's feedback on what values work well for them (it should be between 0.2 and 1.0)
    Improvements over 3.0.1-rc1
    1) Rate Roll, Pitch and Yaw I fix when we hit motor limits
    2) pre-arm check changes:
        a) double flash arming light when pre-arm checks fail
        b) relax mag field checks to 35% min, 165% max of expected field
    3) loiter and auto changes:
          a) reduced Loiter Pos P to 0.2 (was 1.0)
          b) reduced Loiter speed to 5 m/s
          c) reduced WP_ACCEL to 1 m/s/s (was 250  m/s/s)
          d) rounding error fix in loiter controller (should remove wobbles when using SimonK ESCs)
    4) Stability Patch fix which was freezing Rate Taw I term and allowing uncommanded Yaw
    If all goes well we will make this the official version very soon so it will appear in the Mission Planner in place of 2.9.1b.
    Thanks!
    @Andre: are you still getting high compassmot values? I was using the same SS ESC's as you but have now changed to some SimonK flashed Turnigy 20A UBEC (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...) and my compassmot dropped from 150+% to 35%, I just changed the ESC's
    Hi all,
    For those having loiter wobble problems I would like to get feedback on what your rate pids are set to. If you have the time I would like you to try reducing your Rate Pid's and especially your Rate D terms.
    If you could post the PID values for Roll and Pitch that you were seeding the wobble on and then what values you tired and what you saw.
    Thanks!
  • I am so impressed with 3.0.1 rc1  It just works!
    Stable mode, loiter, RTL, auto all work perfectly!
    I did struggle a bit getting it to arm the first time until I learned about the mandatory pre-flight calibrations, which is a good idea in hindsight.
    I have one nagging issue that isn't 3.0 related.  I had this issue with 2.9.1 as well.  When in loiter, my altitude jumps around quite a bit.  Is this typically a vibration issue, or something with the barometric pressure sensor not being shielded well enough from prop wash?  What should I be looking at in my to help me determine the cause and what to be looking at?
    Horizontal position holds unbelievably well.  I was just out flying 15-20 mph wind and in loiter mode, it stayed in about a 4' circle horizontally.  Almost unbelievable!  :-)
    Thanks in advance and to the team for really AWESOME software!
  • Have the mission planner issues been resolved?
  • Loiter test of my 3DR Hex using version 3.0.1 rc1 after solving problems with magnetic and GPS interference.
    https://www.youtube.com/watch?v=GMynCRUDJPg
    GPS interference improved by mounting on a elevated support on the top plate.
  • Positive feedback 3.0.1-rc1. Took the quad to test loiter at the beach in sustained winds 23 mph, clearly a great improvement over 2.19b.  Expecting bright sun and high winds, we placed a centimeter of black fabric directly over the pressure sensor, inside the 3DR APM case that came with it.  Our voltage is off by ~ 0.5, for this MP version, could not find the APM Input Voltage to adjust it (did not try to change the default voltage divider).
    https://www.youtube.com/watch?v=oFfHgeSO2RE
  • I tried to use CONDITION_YAW in 3.0 via the mission planner over the weekend and had the following results:
    1. The absolute/relative flag is ignored.  The turns are always relative.
    2. The CW/CCW flag is ignored.  Turns are always clockwise.
    3. Negative values for turn amount are ignored. No turn is done if you put in a negative value.
    4. Values over 180 degrees are ignored, no turn is done.
    On the other hand, the ROI command seems to work well, except that it causes significant jerkiness in the motion of the copter.
    I don't have a gimbal on my quad and was trying to use the heading of the copter to film a tour of a location.
