ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      Nice video.  Great to see spline in action.
      • Randy,
        I read the wiki and it said in 3.2 DO_SET_ROI will hold the nose without entering multiple commands, as shown this video it did just that.  Problem is I have clue how to cancel and get it to return it back to normal yaw(nose) position.  So once set seemed as it was always set.  How do I cancel the DO_SET_ROI?  Do we need an END_SET_ROI?
        http://copter.ardupilot.com/wiki/mission-command-list/#Do-Set-ROI
        (Note: in AC3.2 it will be possible for DO_SET_ROI without entering multiple commands).
        Thanks, Ed
        • IIRC, a DO_SET_ROI with lat,lon set to 0,0 cancels the command
  • Hi Randy en dev team,
    My first impression about 3.2 rc2, I put EKF on channel 7, changing it on an off I noticed that with EKF the quad doesn't have any twitches, more stable in the air and althold and loiter were also working great.
    Greatest visible difference for  me was in stabilize with or without EKF, with EKF the quad looks like hanging on a wire,
    Weather was perfect during testing NO wind.
    I still have to test the new hybrid flight mode but stabilize is my most used and that worked better than 3.1.4
    I used the pids from autotune 3.1.4, is het recommended to do a autotune with 3.2 with EKF activated?
      Peter,
           Txs for the report.  The EKF shouldn't affect the autotune so you should be able to stick with the previous PIDs.  Generally the EKF (which only runs on the Pixhawk) should perform just like the existing DCM+inertial nav (it replaces both) although it should be more resistant to vibration and other sensor noise.
      • " more resistant to vibration and other sensor noise" could explain hat the quad looks and flies more stable?, When EKF enabled there were no more little twitches and also altitude hold looks like it's doing the job better then without EKF
        Are with 3.2rc2 on the pixhawk the stabilize loops 400Hz or still in APM compatibility 100Hz?, is this the onion structure?
        But so far I love it :)
    • Same question I posted here earlier but there's no response, even from the dev team.
  • @christian , thanx for the list. i did not realize that the sunrise 20A ESC have SiLab processor. I have ordered sunrise 20A BLheli firware ESC. I am glad the ESC in in this list. the list should be updated regularly since there so many brands of ESCs in market. I still think the ESC sync  with pixhawk is a major issue and could be a cause to some unexplained crashes. honestly, i never had a crash in last two years. this is my first crash (really bad) and i would try to eliminate this cause forever.
T-MOTOR liked T-MOTOR's profile
15 hours ago
DIY Robocars via Twitter
Jul 4
Jul 4
Jun 25
Jun 25
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
