ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
          • Hi,
            could anybody figure out what causes our issue?
            that would be great if I could use auto mode and continue testing… :(
            regards
            Adrian
            • Hi,
              I made several test flights, the issue is always the same… :(
              Any ideas how to solve?
              BR
              Adrian
  • now I know what feels wrong with the Drift mode...(in my opinion) it should be executed with the yaw stick not the roll stick.. its not natural to yaw with the roll stick and that makes you feel like you will crash any moment because you have no control on yaw after you slow down. if you hover it should yaw with the yaw stick and even in fast moving you should still have a bit control on yaw if needed, but thats only my 2cents.
    • was thinking similarly... if the yaw stick acted like a rudder, it (drift) would be perfect.
  • How do you people calibrate your accel sensor??!!its almost impossible to do it properly...no way when you place your multi on legs,no legs are exactly the same...ok,i know,you can level by putting something equal size under arms but what about when you press Pixhawk and antivibration pads are not leveled any more when you release it...did any of you use leveler and check?no way you can place leveler on Pixhavk bcs of all stupid connectors on the top!
    Another issue is putting your props in the same level with controller on a round carbon tubes...i put safety screw thru clamps,but still,if you hit something with arms and props its not leveled any more....but that's my problem when I deceide to use carbon round tubes instead of squere ones...
    • well you need to level your frame not your board, so all those connectors dont really matter :)
      • No,point is,your board have to be leveled with your frame!how else?????
        • no i dont think it does. in fact its not even possible with the flexi foam mounts etc.
          the level function exists to counteract small differences between the board level point and the frame level point - you level the frame, not the board. the frame is the flying object.
          • I cannot agree with you....and I think its a bad practice not to level board with frame....I might be wrong ofcourse...thx for answer anyway..
            • Emin,
              You level the frame.  The whole point of the leveling exercise is to  tell the flight controller when the frame is level.  Ideally the board and frame are very close
