ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • HI
    please to see log
    http://forum.rcdesign.ru/attachment.php?attachmentid=948772&d=1...
    ac 3.2  stop motors in altitude hold mode when rc3 in 950 (rc3min = 1008)
    user error - throttle failsafe -disabled
    arducopter dont hold climb rate - full stop of motors
    http://forum.rcdesign.ru/attachment.php?attachmentid=948772&d=1402686342
  • APM and rally points?
    Why are rally points for Pixhawk only? I have APM 2.5 in an aircraft and rally points work very nicely. Why airplane but not multirotor?
      Mike,
           We've run out of flash place on the APM1/APM2 so we cannot include all features at the same time on these boards.  Pixhawk has much more flash space so we can include all features on that board.  ArduPlane is also almost out of flash space I think but it's still slightly under the limit.
  • Auto Mode bug found. Has anyone else had this problem?
    http://diydrones.com/forum/topics/i-need-tuning-help
      Mike,
           Thanks for the report.  It's a known issue with AC3.2-rc2 but it's fixed in master so it'll go out with AC3.2-rc3.
  • Quote
    Permalink Reply by MICHAEL on June 3, 2014 at 7:01am
    Hi just installed v3.2 rc2 all went well but when i connect to the terminal so a can do a erase and clear
    calibrating barometer appears and then a whole bunch of code keeps on going. How do i stop this so a can gain access the the commands to clear and erase like i always do after a new firmware install.
    Thanks for the help
    Does anyone have an explanation on how to erase and clear APM 2.5 with v3.2 rc2?
    • see note 11 on page one.
  • Just loaded 3.2 via mission planner onto my test quad with a PX4. Only test hovered inside but copter has become ultra twitchy. Anything that has to be change upon installation for a DJI 450 size quad frame?
    3.1 was perfect but I really want to try Hybrid mode as it looks mighty impressive!
    • Well.....that was scary! The copter dropped, sat on the carpet idling motors not responding, was about to try to get the battery unplugged and the went to full throttle and smashed into the ceiling!!!!!!!!!!!!!!
      First time any of my Arducpter craft did anything like that!!! Luckily no injuries or major damage but be careful with this version on a PX4!!!!!!!!!!!!!!!!!!!!!!
      • Logs?
        I wonder if you had a GPS event indoors and it tried to RTL?
