ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • APM and rally points?
    Why are rally points for Pixhawk only? I have APM 2.5 in an aircraft and rally points work very nicely. Why airplane but not multirotor?
      Mike,
           We've run out of flash place on the APM1/APM2 so we cannot include all features at the same time on these boards.  Pixhawk has much more flash space so we can include all features on that board.  ArduPlane is also almost out of flash space I think but it's still slightly under the limit.
  • Auto Mode bug found. Has anyone else had this problem?
    http://diydrones.com/forum/topics/i-need-tuning-help
      Mike,
           Thanks for the report.  It's a known issue with AC3.2-rc2 but it's fixed in master so it'll go out with AC3.2-rc3.
  • Quote
    Permalink Reply by MICHAEL on June 3, 2014 at 7:01am
    Hi just installed v3.2 rc2 all went well but when i connect to the terminal so a can do a erase and clear
    calibrating barometer appears and then a whole bunch of code keeps on going. How do i stop this so a can gain access the the commands to clear and erase like i always do after a new firmware install.
    Thanks for the help
    Does anyone have an explanation on how to erase and clear APM 2.5 with v3.2 rc2?
    • see note 11 on page one.
  • This reply was deleted.
      • Logs?
        I wonder if you had a GPS event indoors and it tried to RTL?
                Andy,
                      I had a look at your logs and something went very wrong with the inertial nav altitude.  The scale is not great in the image below but in any case, the inertial nav altitude estimate is in green.  It bounces around between +20 and -60m for the first couple of minutes and then it shoots up like a rocket to 2.9km and then drops again to -600m.  This is certainly the cause of the behavior you saw:
                   a) When the alt climbed above 100m it triggered the altitude fence and switch to LAND mode.  Because it thought it was climbing it reduced the motors to their minimum and you saw the vehicle come down.  Even though your throttle was at zero, it didn't automatically disarm because it didn't think it had landed (because the climb rate   >500m/s).
                    b) when the inertial nav alt peaked and started falling, the vehicle now tried to slow it's descent by ramping up the motors and then it crashed into the ceiling.
                3702897493?profile=original     I've never seen this but I think the cause is your backup accelerometers haven't been calibrated.  We've added support for redundant accelerometers and gyros but we have not extended the pre-arm check to ensure that both are calibrated so we better add that!
                     We don't have a chorus of people running into this because most users of PX4/Pixhawk are new and so they wouldn't be carrying over their parameters from AC3.1.
                3702897097?profile=original     I'm very sorry for your troubles, we will confirm this is the issue put a warning at the top of this thread to tell people to redo their accel calibration and fix it for -rc3.
                  • Andy, did this work for you? I'm also having issues with altitude on PX4/PX4IO, even in 3.2-latest of june 11th. My report is on page 37 of this thread. In EKF-mode the altitude sticks at 15000 meters after a few minutes and in 'legacy'-(non-EKF) mode the altitude drops to a steady 0 meters after a few minutes.
                    And also @Randy: I was under the impression that PX4 does not have a backup accelerometer. After calibration in 3.2 (latest and rc2) INS_ACC2* all are zero.
                    Thanks for looking in to this!
                    Andy,
                         I think if you connect your px4 as it is now (i.e. without the backup accels being calibrated) to your PC with the USB cable you'll see the altitude (via the mission planner) move all over the place especially if you lean the board.
                         If you re-do the accel calibration and repeat the test I think it'll be a-ok.
                         Thanks again for this important report.
