ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • I loaded latest FW 3.2-rc3 into my Pixhawk yesterday with EKF on and flew the x4 3dr quad multiple times with stabilize, hybrid, auto, guided, circles and RTLs without any incidences.. Landings in RTL shut off perfectly.. The stuttering in auto was gone.. I did notice minor and rare jerks in auto.. Subjectively the flights were very much improved with confidence.. Thanks, all..
    • Loaded the "latest" AC 3.2-rc3 into APM. After several flights,  I am please to report that Stabilize, Alt-Hold, PosHold Modes were great! Flying in Auto mode was so smooth even in changing altitudes between spline waypoints. Region of interest works so well....it's fun to watch. Nice Job!...Many thanks and appreciation to all of you. Enjoy!
    • Edward how did you get rc3, I don't see it in MP beta yet?
      Thanks, Ed,
  • checked today and AC3.2-rc3 on APM also is freezing up after code is loaded
  • Testing 3.2 rc2
    Any reason why RTL and Loiter work great but Hybrid mode starts to drift (ie. doesn't seem to lock properly on gps). I'm using a Taranis and have confirmed my trims are centered. I did use auto trim to adjust the internal trims. Could this be throwing off the apm sensing my sticks are centered? If so, I was under the assumption the apm would adjust what it perceived as "no stick input" based on its auto trim.
  • I'm looking forward to trying rc3 in a few days on a small 250 quad I'm completing. I am also modifying an 800 quad and installing a Pixhawk. I have a ballistic chute that I want to use and 8 b) above mentions parachute support. I can't find anything on how this is implemented so could you please direct me to a relevant thread or documentation?
