ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • Loaded the "latest" AC 3.2-rc3 into APM. After several flights,  I am please to report that Stabilize, Alt-Hold, PosHold Modes were great! Flying in Auto mode was so smooth even in changing altitudes between spline waypoints. Region of interest works so well....it's fun to watch. Nice Job!...Many thanks and appreciation to all of you. Enjoy!
    • Edward how did you get rc3, I don't see it in MP beta yet?
      Thanks, Ed,
      • This reply was deleted.
        • ty, whats the diff in
          quad-hil and quad?
            • Thanks, so since I don't use the simulation I don't need it I assume, I'll just get quad, thanks!
  • checked today and AC3.2-rc3 on APM also is freezing up after code is loaded
  • I see RC3 in the 'latest trunk' version in Mission Planner, but it doesn't show up in 'Beta firmwares' in Mission Planner, so does this mean not to use RC3 as a 'beta' level yet?
      Rich,
           -rc3 will be out shortly, probably later today or tomorrow.  It's close which is why I've updated the version name in master (aka 'latest') but there's a technical issue (the pixhawk is freezing up after code is loaded) that's come up when we use the latest version of the arm gcc compiler for Pixhawk.  We just want to make sure we understand the cause before pushing out the new version.
      • Thanks for the update. Sorry for seeming to be impatient.
        Having a Pixhawk, I'm happy to see that you're looking out for the PixHawk version. :)
  • Any news on RC3 yet? :) or where can we go to follow the progress?
    • Dear Randy,
      I saw in repo that RC3 is ready and out.
      When it will be available in Mission Planner? (I have the latest beta…)
      Thanks in advance.
      Best regards
      Adrian
