ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      OwlPic,
           Yes, the time has come to update the manuals.  We will be starting on that shortly.  The first order of business is the modified sonar & range finder pages because the set-up is very different now.
           Which links do you mean by the way?
  • Tried 3.2-rc3 yesterday - Everything seemed to work Ok but drift mode still turns very slowly.
      Gary,
          Ok, thanks for the report.  We will have a look.
  • i did about 50 auto missions with AC3.2-rc2 and did not have a issue in Auto, stabilize, RTL, battery Failsafe, Loiter. Only in Hybrid mode the craft keeps drifting upto 5meters before holding position. my frame is a 3DR frame (old type) with 2830-920KV motors. 5200 walkera battery.
    • I have the exact problem. Was really excited to try out hybrid mode but completely perplexed that all other auto modes work great.
        At long last ArduCopter-3.2-rc3 (release candidate #3) is now available through the mission planner’s beta firmwares link.  The list of changes can be found in the ReleaseNotes but I’ve also copied them below.
         There’s one change in behaviour which you should be careful of which is 3a, “disable pilot repositioning while landing in RTL, Auto”.  If you’ve gotten use to changing the vehicle’s horizontal position as it lands in RTL or Auto and you’d like to keep that behaviour you’ll need to set the LAND_REPOSITIONING parameter to 1.
         As for when the official release will happen.  There’s still a good number of items on the to-do list but we are also already way overdue on the release schedule so some of the items will need to be shifted to AC3.3.
         Anyway, please be careful when testing and report any issues found  here.  Thanks for your help!
    ArduCopter 3.2-rc3 16-Jul-2014, Changes from 3.2-rc2
    1) Hybrid renamed to PosHold
    2) Sonar (analog, i2c) and PulsedLight Range Finders enabled on Pixhawk (Allyson, Tridge)
    3) Landing changes:
        a) disable pilot repositioning while landing in RTL, Auto (set LAND_REPOSITION to 1 to re-enable) (JonathanC)
        b) delay 4 seconds before landing due to failsafe (JonathanC)
    4) Secondary compass calibration enabled, pre-arm check that offsets match current devices (Randy, Tridge, MichaelO)
    5) Control improvements:
        a) use bias adjusted gyro rates - helps in cases of severe gyro drift (Jonathan)
        b) bug-fixes when feed-forward turned off (Leonard)
    6) TradHeli improvements (RobL):
        a) bug fix to use full collective range in stabilize and acro flight modes
        b) filter added to main rotor input (ch8) to ensure momentary blip doesn't affect main rotor speed
    7) Safety items:
        a) increased default circular Fence radius to 300m to reduce chance of breach when GPS lock first acquired
        b) radio failsafe timeout for late frames reduced to 0.5sec for normal receivers or 2.0sec when flying with joystick (Craig)
        c) accelerometer pre-arm check for all active accelerometers (previously only checked the primary accelerometer)
    8) Other features:
        a) ch7/ch8 option to retract mount (svefro)
        b) Do-Set-ROI supported in Guided, RTL mode
        c) Condition-Yaw accepted in Guided, RTL modes (MoussSS)
        d) CAMERA dataflash message includes relative and absolute altitude (Craig)
    9) Red Balloon Popper support (Randy, Leonard):
        a) Velocity controller added to Guided mode
        b) NAV_GUIDED mission command added
    10) Bug fixes:
        a) bug fix to flip on take-off in stabilize mode when landing flag cleared slowly (JonathanC)
        b) allow disarming in AutoTune (JonathanC)
        c) bug fix to unpredictable behaviour when two spline points placed directly ontop of each other
    • Randy,
      I know you're always busy, first thanks for RC3, but regarding this:
      To me it seems smarter to allow the pilot to be able to reposition the aircraft if needed on landing, before I enable this setting, can you tell me the reason why it was disabled in the default settings for RC3?
        Rich, Raph,
            We had a at least two long debates in the dev team about whether we should allow horizontally repositioning the vehicle as it Lands in an Auto mode or not.
        Arguments for repositioning: We should allow it because it makes it easier to reposition the vehicle at the end of the mission to ensure it lands on flat ground.  It's also the default behaviour in AC3.1.5 and earlier versions.
        Arguments against: (a) if the pilot wishes to take control during autonomous landing, he/she should should switch to loiter or PosHold mode where he/she has full control of all axis instead of trying to beat the clock and get the vehicle into position as it comes down.
        (b) We've seen a few crashes caused by people incorrectly setting up their failsafe so that their roll or pitch channels went to zero meaning the vehicle flew home fine in RTL but then sped off during the landing portion.
             We couldn't agree, so we added a parameter to allow selecting the behaviour.  There's an open question about whether the default should be allowing or disallowing repositioning.  For now at least, I've set it to disallow because of the crashes.
        • I will definitely change the default to allow nudging as I don't like to be locked out of pitch and roll. I live in a woodsy environment and may need to avoid a tree or something if I'm landing in a tight space.
      • I am curious as well..
