Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Thanks for the testing. I'll check the auto-disarm feature for the althold, loiter, etc flight modes.
For the other issue, a dataflash log file would be a great help.
Randy, You want the log files? about rally point, condition YAW?
And what about idea for pause automission improvement? what do you think?
Hello Artem. I'm not seeing any pulsating in alt hold.
Randy,
Before day, I had test RC4 (Stabilize, ALT Hold, Loiter, PosHold, Auto, Guided, RTL) with EKF is very perfect. But, I have problem is no auto disarmed when have battery failsafe with itself when down to land. I need move throttle down for disarmed after it have to land.
Balloon,
Thanks for the report. I think that's always been the behaviour even with AC3.1.5... when the vehicle lands it requires the pilot to put the throttle to zero before disarming, The only time this doesn't apply is during a radio/throttle failsafe because the pilot has no control of the throttle.
Phil,
Thanks for the report. The one re the yaw is just as you say, it's using the current heading instead of the target. There's even a to-do in the code about it so this is fairly easy to sort out.
As for why RTL is getting stuck, I've looked at the logs but haven't figured it out quite yet.
Randy,
What about Rally points? As I told you, it no work and when it's set it cause RTL behaviour! (AC3.2Rc3 PIXHAWK, and I check release notes for AC3.2Rc4....)
Condition YAW absolute ok but relative no work.(if I set 90° relative, copter only achieve 30-45°, I thinks issue for condition yaw relative is due to use current yaw at intant when Condition YAW is invoked..I think that for condition yaw relative work finly, is better to calculate relative yaw from the expected yaw between 2 waypoints, what do you think?
For pause auto-mission, it works, but there is possible to move current waypoint number variable to eeprom? like this even when copter no finish big mission due battery level, and auto invoke rtl and land and we change batteries (reboot), when we restart mission, automatically copter go to waypoint targeted just before rtl?
also I noticed that when switch back to auto mission mode after having paused, all the functions such as do_set or condition_ commands are not reactivated, it would be possible to ensure that all (or the last ones) of the do_set_ and conditon_ be before current waypoint be reprocessed when switching back to automission?
Regarding RC4 and direct throttle feedback from pilot thr input before takeoff in LOITER ALHOLD POSHOLD no work.....Just little difference with RC3 is that when pilot star to up throttle, RC4 step up by 10% throttle off motors, and take off when pilot throttle input goes up by 50%, So no direct feedback before take off like dji...
Only for Pixhawk board
https://github.com/diydrones/ardupilot/pull/1266
193
194
195
196
197
of 262 Next
