Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
AMP 2.6 using 3.2 rc7 Arducopter Droid Planner 2.6 Beta from
http://3drobotics.com/2014/06/follow-me-mode/ "using Nexus 7"
Follow Me works just fine with this setup.
Now 3.2 rc9 I can't get follow me to work. I do see a new droid Planner which I have not
updated to yet.
Thanks Rainer for your feedback.
Hi Marco.
I am unable to use Hybrid Mode / PosHold with my Walkera QR-X350-Pro (APM Copter 3.2). Loiter works fine, but it does not change into PosHold mode in Mission Planner when I activate it. Nor does it work flying. Any idea why this might be? I noticed a few other people are also experiencing this problem with their QR-X350-Pro.
If you have any ideas, I would greatly appreciate it. Thanks again to all you guys for your great work! ;)
- BaNe
I'm sorry but i don't know what firmware is installed on that machine.
It's possible that we have removed some features.
Actually, with the latest firmware from Walkera, Loiter is flying fast now. But, I am trying to fly a 40 meter circle. But, I get a partial circle then a corkscrew towards the center. Any suggestions on the Circle_Rate parameter? I believe the quad has a version of AC 3.2. So that's in meters? Thanks, Brother.
I found out PosHold doesn't work on my Quad. But, the new Loiter is fantastic.
Pic 2 sonar reading when lifted about 20cm
hi,
the minimum distance the sonar can measure is 20 cm. This is normal.
Definitely the bad sonar alt is not good and I'd expect problems when landing in AltHold or Loiter so we should get to the bottom of the problem.
While landing in Auto, RTL it should be ok because it doesn't actually use the sonar for that (it just sets a target speed).
