Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Yes, and happy to contribute the adjustment back, I am truing to determine if there is anything to the "Stream Tube" effect at this scale, using a higher KV motor on he bottom, I am not looking for the use of the configuration to be redundant rather focusing on performance, If I carry the layout forward can I assume I could build up a complete profile for the frame and alternate motor configuration? I had located that file and thought it was the appropriate place, most seem to be in the AP_Motors library, the Config.h file and some of the setup locations. I did start a forum thread on the project, and will be documenting the progress.
Adding to the groundswell that 3.2_rc10 is looking pretty stable...
I just updated my 3DR Y6B from AC3.1.5 to 3.c_rc10. So far I've flown with Stabilize, AltHold, Loiter and RTL which all work nicely; congrats again to the Dev team.
(PS. Can anyone suggest the best parameter to adjust throttle sensitivity? My copter hovers at around 50%, but it's very difficult to find a stable sweet spot).
Daniela,
I've replied over on your disucssion.
I am not sure what is best FORUM to reply to newest 3.2 r10 update findings for PIXHAWK , I posted my problems here : http://ardupilot.com/forum/viewtopic.php?f=21&t=9788&p=2361... , but I see this discussion is up to date with all newest release problems.
second question:
new firmware release for PIXHAWK comes with 2 files : *v1.px4 and *v2.px4 , cant find why are there 2 files instead of 1 ?
I loaded v2 only because v1 gave me some errors about identifying boards before firmware upload.
I believe the v1 is for the first board labeled as PX4 (https://code.google.com/p/arducopter/wiki/PX4board) the v2 is for the Pixhawk board.
I have tried 3.2 RC10 on my TBS Disco and QAV500 yesterday and today, so glad that they fly perfectly in mode Stab, Loiter, Poshold. Even in strong wind (30 km/h) loiter Mode was so stable. As a noobie I just fly LOS in short distance with hard bank to left and righ on hight speed, feel locked-in in my setup. RTL also working good with 100cm dist from home point.
The only problem is when I check logs I got confuse beetween TBS and QAV logs because there is no name tag or whatever to recon those two logs. It is nice maybe if we can put title/name in parameter setting rather than remembering the logs time stamp.
Thanks for great work
Yana
Last night I got 3.2 to work nicely on my trad heli. A few problems.
1. In 3.1.4. if I shut off my radio, it would default to RTL (because my Futaba tx/rx were setup to send that signal as failsafe). Now it won't change the mode to match my Futaba failsafe.
2. You can see in the video when flying spline, it jumps a little when it hits a waypoint. Is that normal?
3. When using the minim OSD, with some custom code that worked on 3.1.4.. On 3.2, the OSD freezes when I switch into auto or loiter and needs a hard reset.
I fixed my lagging heading problem by changing yaw behavior from 3 to 1. Now my splines look sweet. This video is full auto from takeoff to land. http://youtu.be/ZSiM43sHF-k
I tuned down the shakes and now the splines are much smoother. I've isolated the OSD problem to a bug in the OSD code, but still need to find the bug.
Hi all together,
today i was trying AC3.2 rc10 on my quad. But i finished with disapointment - quad could not fly more than 3-5 seconds.
Started OK in stab mode, GPS lock OK. But when i lifted it aprox. 50cm above ground it started to loose response - like each RC channel was still more and more supressed. I guess it didn't happen suddenly but the loosing was graduated within time interval of 5 second. After that quad descend down and hit the ground bit hard. Fortunately not damages.
Now the questions and facts:
Whole initial procedure performed (compas, accels, RC calibrated)
Battery full loaded
I flown quad with ACM 3.1.5 with no problems - was very smooth and i was really happy with it.
Have no logs, because i compiled ACM 3.2rc10 without logging - hoped to lighten the control loop.
Now i compiled it with logs enabled, log mask set to 2046:
MASK_LOG_ATTITUDE_MED
MASK_LOG_GPS
MASK_LOG_PM
MASK_LOG_CTUN
MASK_LOG_NTUN
MASK_LOG_RCIN
MASK_LOG_IMU
MASK_LOG_CMD
MASK_LOG_CURRENT
MASK_LOG_RCOUT
Not sure if IMU is necessary for further analyse, but i turned in on too.
Could be the problem i'm using still APM 1.x with Arduino 2560?
Randy,
I just loaded RC10 on my Pixhawk H Quad. So far its a complete fail.
When I loaded RC10, Mission planner indicates that the compass is not calibrated, (as well as the ever present AHRS failure that has been here for a bunch of RC's) so I did the compass calibration dance - just as I have done dozens of times with MP and this exact quad. It completes with 3 offsets all less than 30. Great.
But I can't arm because MP says "prearm compasses are inconsistent".... I have re-done the compass calibration and gotten the exact same result... Help this is a complete fail.
this is all 3DR hardware and has flown as is for nearly a year...
compass 2 has readings with exponents to 7th or 8th power... somebody missed something in the cal code.
compass offsets WTF.docx
110
111
112
113
114
of 262 Next
