Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Today I I flew my TREX 800 Trad Heli on 3.2rc12 for the first time (up from 3.1.4). After a little tuning, It was flying just as good as my 550. It's sweet to see such a big machine do splines. Sorry, no video today.
I've attached a 550 log from a few days ago. The reason is that I'm having a repeat problem. The heli won't land after a mission, It just hovers without descending (forever it seems). Anyone know why?
5.BIN
It is awesome to see APM is working well on trad. helis.
Any chance I can see a video of the flight somewhere?
http://youtu.be/ejh5IXx85P0
There are some on Rob's channel too.
http://youtu.be/kQj50ykhEnQ
I watched the old video (first link). I am a bit confused. Is this entirely an auto mission from take off to land?
The chopper was moving so fast, turns were so quick. It just look to me that someone is flying it.
I generally watch multicopter flights. And comparing to multicopter flights, this one looked really different.
So is this entirely an auto flight? You didn't touch the radio sticks at all?
Helis are designed to be very responsive. APM can take advantage of that control authority and make aggressive movements. Plus, I want my Helis fast. So I tune them fast.
I am really amazed. I have seen traditional helis with flight controller before but the flights were very slow and steady.
Ray,
I had a quick look at your log and couldn't immediately figure out why it wouldn't land. normally it's because the WPNAV_RADIUS or LAND_SPEED is set to zero but from the parameters shown in the logs, that doesn't seem to be the issues. I'll have another look.
tested RC12 again and noticed that unknown sound during arming. I did another flight directly before, where I landed in loiter.
After disarming I switched to AltHold and tried to arm again. Nothing happend but that sound. I disarmed although it was not armed?! and now it was possible to succesfully arm the copter..
It happened to me one time with RC10 too. Tomorrow I can provide Log if needed.
Just listen:
Hello
look at the HUD with telemetry, because you see the errors
This is the "baro glitch" sound:
http://planner.ardupilot.com/wp-content/uploads/sites/5/2013/06/Bar...
