ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • Yes I get that too. It has been a bit frustrating for me as I spent a great deal of time building a waterproof quad so I could get low level high definition video over water but because of this issue it was impossible. The copter would go up and or down 20 meters on high speed runs. I was better off in stabilize mode. I left the battery door open to see if it was the equalization vent but it was not. What would happen with me is on a high speed forward run it would drop to the point I have to increase the throttle then as I slowed down it would shoot up 20 meters. It seems like there could be a firmware solution for this. If forward speed created a lower altitude seems like this could be automatically be adjusted. Might not work going in reverse real fast but I'd say that would be a decent trade off.
  • i test arducopter 3.2 rc12
    apm
    2 different gps with nmea output (38400 baud VTG GGA 5Hz)
    in mission planner show "no gps"
    blue led off
    i test different gps settings 1 (auto), 5(nmea) - no difference
    when i use AC 3.15 firmware - all work fine
    • hi please find attached log at 2.5 mins roughly my pixhawk quad in loiter veered to the left quite sharply then restabilized with 3.2.rc 12 two gpss plugged in main one 3dr 6h and neo 7 as second using neo7 compass as its
      at the front don't know if this would affect ant thing
      about fourth flight with rc12 no probs but at the 2.5 min mark I got
      err gps2 and  err gps 0 could this be a flaw as pixhawk switch from one to another ?
      or does this err mean something else ?
      tried loiter and rtl both worked fine after
      stuart
      • i test gps modules separatly
        as primary gps at APM controller
        NMEA protocol on APM is not work
          Alexey,
          Yes, you're right.  Due to flash space constraints we dropped NMEA and SIRF GPS Support in AC3.2.  It's possible to re-enable them if you're compiling the code yourself.  It should work by simply commenting out this line from AP_GPS.h:
          #if HAL_CPU_CLASS < HAL_CPU_CLASS_75 && defined(APM_BUILD_DIRECTORY)
              #if (APM_BUILD_TYPE(APM_BUILD_ArduCopter) || defined(__AVR_ATmega1280__))
          //        #define GPS_SKIP_SIRF_NMEA            <---- comment out this line.
              #endif
          #endif
          Although in my testing I found I needed to comment out this line in AP_GPS.cpp where the GPS_SKIP_SIRF_NMEA definition is checked.
          These two GPS drivers consume 4k of flash and we're simply out of space on the APM2.  We could potentially create an alternative set of binaries for people to load themselves with the "Load custom firmware" link of the mission planner.
          • Randy,
            thank you very much for your help!!!
            of course i will compile hex file for myself and for my friends
            all modules ublox, sirf & mediatek  is support nmea protocol
            maybe select it by default for compatibility in next relises ?
              Alexey,
              No problem.
              SIRF and NMEA are available by default on Pixhawk but we just couldn't fit it on the APM2 without dropping support for something else that seemed equally important.
              So I won't be able to enable it by default for the next release.  What I can do is sacrifice some other feature (like Sonar) and create a special binary for a limited number of frame types (like quad, tri, hexacopter and octacopter).  I'd probably put those into the ardupilot.com/downloads area.
              • of course!
                maximum 1-2% of APM users use sonar.
                support of lots types GPS is more important!
      • sorry cannot upload log too big
        stuart
  • Hi Randy,
    This is my logs from a flight i did while chasing a ship. Seem to be an EKF issue or maybe the boat was too rocky. Maybe you would want take a look if there is an issue as im not too sure.
    And also, I want to mention, the loiter on RC12 is rock solid. I was about 70 meters up and wind was quite gusty. Seem like someone paste a drone sticker in the sky. *thumbs up*
    Thanks!
