Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Did you balance the new larger props?
If not then do it, cos all the times that people here have had quads fly away or climb rapidly in any mode other than stabilize it has been due to high vibrations causing the flight controller to want to climb.
Check for high Z values in the logs also!
My pixhawk running 3.2rc13 tried to fly away yesterday. After a few resets, it works again (still a little glitchy). I think I'll reset, recalibrate and reload.
In the tlog, you see that it had compass issues so I recalibrated compasses and tried to fly.
Upon switching to auto it took off and then...the heli tried to fly over the trees. I took control manually and brought it back before the trees (although the telemetry shows where it would have gone had I not taken it). As I brought it back manually, it was a little difficult to control and out of trim but I brought it back OK.
Looking at the telemetry shows that it was way out of whack for a little while.
Bin file shows tons of glitches.
I'm glad I had the switch to stabilize ready to go.
2014-11-06 12-13-35.tlog
34.BIN
Randy and Co.
I've noticed a problem that surfaced recently. In both of my helis running 3.2 rc 13 (EKF). When I disarm after a flight, the position of the craft returns to home. No matter where the craft is, telemetry has it smack dab in the middle of the home circle. An Arm or FM reset will solve it but it still is an issue if I want to see where my heli is after disarm.
An example in the attached log:
After a flight that lands at a rally point at 34% the position zips to home back on the taxiway on disarm at 35% (it's still at the rally point at the end of the runway). I rearmed and flew some and then hand-carried it back to the pits 58-60%. (still shows at end of runway).
I worked on it until the end of the log in the pits but still showed the wrong position.
I looked at a log from the 25th of October and this problem is not there. Two things that have changed: EKF enable and rc13 from 12. Anyone else experiencing this?
2014-11-06 11-40-31.tlog
The cause of this problem is the EKF enable. When I switch the EKF on, the heli position lat long erroneously indicates that it's at home (while disarmed). As soon as I change AHRS EKF Enable to 0, it works fine and valid position is indicated.
I'm running rc 14 now. I like EKF but don't like erroneous indications. Is this just my problem?
I've just made a blog post asking the wider community to give AC3.2 a try (stil through the Beta Firmware's link).
So if you download the BetaFirmware version now you should find that it's AC3.2 (if you look closely at the top of the dataflash logs or if you are using Pixhawk you can use the terminal window). This version is renamed but it's exactly the same as -rc14.
Thanks again to all you who put your copters at risk during the testing of this major release!
@stubugs,
No, I haven't seen that before and we don't have a setting like that..
@stubugs,
I've tried to recreate the problem but I'm having troubles. Can you tell me what your vehicle's LOG_BITMASK is and how you're finding the problem. I've done this:
1. set LOG_BITMASK to "NearlyAll"
2. connected to MP with USB cable, armed, disarmed, downloaded log.
3. disconnected USB cable, reconnected USB cable
4. connected, all logs are there.
I've repeated the above tests with LOG_BITMASK set to "All+DisarmedLogging" and the results were the same.
The only things I noticed that I hadn't noticed before was that you can't download logs while the vehicle is armed. Also if you download the latest log (i.e. the one that is currently being written to), when you re-arm the vehicle, that last log doesn't seem to grow. It seems when you download a log, logging is stopped and it can't be restarted unless the board is rebooted.
Randy,
Wouldn't having the log bitmask set to "All+DisarmedLogging" explain this? Can the beta MP set this yet or would it need to be set manually?
Nathaniel ~KD2DEY
Testing AC 3.2-RC14 on full auto with spline waypoints. Pls see attached...
Alex,
hmm.. a number of people have reported issues with AutoTune. The only thing we've done is extend the highest and lowest numbers that it can reach. Perhaps we should back that out..
37
38
39
40
41
of 262 Next
