ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
    • Both compasses have high offsets. GPS modes need a good compass reading.
  • I'm sure this has been answered, but couldn't find it.
    When attempting to download logs via Mavlink (usb), I get "error receiving log list". What is the causing that?
    Thanks.
    • This reply was deleted.
      • 3.2
        1.3.17
          • Hello Alex
            Thanks for taking the time to help.
            To answer a few questions,
            Set PID's back to default
            Their is foam over the Barometer sensor
            Increased  INS_MPU6K_FILTER to 10 the 20. Default 0. Noticed slight improvement
            Note INS_MPU6K_FILTER set back to 0 for log
            Throttle set to mid
            Props balanced
            Balance of copter good. Hung by string at mid point.
            Still pulses in alt and loiter
            Log attached Default + IMU
            Hope this helps
            Cheers John H
            New Zealand
    • Can you test by using a house fan or something indoors and see if it affects the altitude reading as you manually rotate the copter at different angles to the wind?
  • H1 all
    I have a problem with POSHOLD.
    I have set the quad up as best I can. It flies very stable in Stabilize mode. and is very responsive.
    When switching to POSHOD it starts to bounce up and down. Motors quick accelerate and decelerate. moving copter about 100mm in either direction. I have set mid throttle as per log.
    Log attached.
    Cheers John H
    3691173134?profile=original
    2015-01-18 19-18-09.bin
    • Another suggestion, check your vibrations level, I had some issue in one copter and that was the problem
  • 3701915334?profile=originalBased on the logs it looks like motor 1 and 3 where trying to keep the copters nose up.  This could have been caused by wind or the front of the copter is heavier.  When you selected Loiter the copter which was coming down would now try to level off which will cause the motors to change.  At that point the copter was starting to pitch over on its right side badly as motor 2 was told to idle with no effect as the copter flipped several times.
    It did recover when you put it into Stabilize mode but then motor 1 went to idle and then to max?
    This is where if we had motor feed back we could see what the motors did.
    Mike
