ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • is this a Pixhawk only or will that be for APM 2.6 as well? that is good to hear!
        • It will be Pixhawk only, because 3.3 will not be published for APM.
          • DOH!!! thanks Rob!!
    • This reply was deleted.
      • Not sure where i got this phobia of Channel 7 being bad, maybe a bad dream or something? but thanks for your response
        • Well, back 3-4 years ago, Ch8 was very very bad, as I believe it put the system into straight RC Pass-through.  This was from the APM1 days, since it was originally designed as an airplane controller.
          • HA! thanks i knew i knew that from some where
  • I have a 650 quad with 12" props on 700kv motors that felt pretty smooth with stock settings. I ran the autotune on 3.2 and it became very very twitchy. I backed off RC feel and roll/pitch sensitivity but it still feels very twitchy. Any advice? Should I take RC feel lower? I can't lower roll/pitch anymore. Should I try autotune again?
    I've included screenshots of my current pids and rc feel settings below.
      • My PID's were whatever the default settings are. I'd have to go searching to find them.
        The copter feels twitchy in any mode, stabilize, alt hold, or position hold.
      • Considering that PIDS's are independand of radio used, here is a screen grab of my 3DR quad PIDS, after "Auto Tune"....
        Really flies well :-)3702684001?profile=original
  • Okay I give up. Pulling my hair out trying to figure out why my quad started toilet bowling and 'flying off' in all directions. I had it all dialed in flying nice but had a prop break in mid flight probably 20 meters up. Had a hard landing but nothing horrible. I get home and decide to upgrade to my shiny brand new taranis and X8R. I also upgraded to the last 3.2  but now I'm having problems. Should not have done so much at once now I'm not sure what the problem is. I simply cannot reliably get poshold to work well anymore it just seems twitchy and often just starts wandering off. It used to hold position within a couple meters easy. I re-did the calibration and compass calibration several times. I keep getting insane high reading on the internal compass.. I have no idea why. If somebody could look at this log and find any clues I'd really appreciate it. It is a 3Dr pixhawk. Ublox7 w/ compass. X8R receiver with Teensy.
    279.BIN
    https://storage.ning.com/topology/rest/1.0/file/get/3701916393?profile=original
