ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • oops sorry.. Just did read your explanation regarding home and launch difference.
  • This reply was deleted.
      • Dieter,are you aware some of the functions can be off on APM bcs. of memory restrictions?
          • Hello
            I think they have a memory-problem-.
            delete the EEprom on the Arduino software. (eeprom_clear)
            install all new, and it will work
  • Hm...this new Vector controller from Eagletree have so many similar functions to Arducopter...I like setup where all fits up together without DIY solutions..
    http://www.eagletreesystems.com/index.php?route=product/product&...
    manual:
    http://eagletreesystems.com/Manuals/vector.pdf
    this is RTF.....
  • I faced with a SBUS / PPM bug. I tried with taranis and futaba all of them working fine with 3.1.5 however I coundn't get it working with 3.2.0 (on the same hardware with lastest build from today)
  • Here is another Spline test for you Randy :)
    It went well, a little jumpy at times.  The jitter on the fly over was my gimbal not the quad.
    • Is that jitter on 0:24?
    • Wow...great video...I want my y6 fly like that autonomously...last pass was very near tower, you have nerves of steel...
    • that was an awesome flight pattern!! I commented on your Youtube video, but thats Tampa Fl, i live there as well!
      • Yep, Tampa FL, its the Sulphur Springs Water Tower.  If you want add me as a friend and maybe we can meet up and fly.
        Here's the final cut, but I don't want to tie up Randy's 3.2 thread so just send me a message.
