ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • thank you - this is about 15 miles from Lake George, NY.
  • I don't know if this issue been reported before but....if you try to arm multi(Pixhawk) without pressing safety button,you cannot arm,only short sound..but if you press button afterwards and arm,throttle response is totally uncontrolled...disconnecting batt is solution to exit that strange mode....is it just me or....?
  • Hello RANDY @ development team
    an error in 3.2rc2 Pixhawk.
    turn on EKF Armed flight OK
    disarmed switch to AHRS. start copter falls on the head.
    Copter without electricity, reboot everything is OK.
    LOGS
    https://www.dropbox.com/sh/qimdohk3oflvh5y/AAD3GHDNIIYXOeLH8Os2sH8ga
    Dropbox - Link not found
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
    • OMG Rainer,how many times your multi crashed..is it still alive? Don't expect fast answer,3DR developers are occupied with some competition they have soon, I guess
  • Hi did some interesting tests/comparison of PWM Levels of KK, APM and Pixhawk.
    http://diydrones.com/forum/topics/pixhawk-causing-motor-sync-issues...
    Could sb confirm that with pixhawk?
    Regards
    Christian
  • Hi, I have a strange issue with 3.2rc2 on both pixhawk and apm2.6 in a tri frame.
    With 3.2 RC2 both loiter, hybrid, rtl modes work great.
    But in AUTO mode, copter flies really slow and bumpy towards the waypoint (pitch direction). It feels like something would always stop acceleration.
    On this screenshot this behaviour can be clearly seen from desired picth value.
    The full log can be found here:
    This is my parameters file (in case I missed something...?!).
    Best regards
    Adrian
    • Hi all,
      I tested 3.2rc2 on a quadcopter with a Pixhawk and and Apm flightcontroller and let them both fly a short mission.
      First with Spline waypoints and then with regular waypoints.
      On my quadcopter with the Apm I observed the same issue as Adrian (see attached picture). On my quadcopter with the Pixhawk the observed behaviour was absent.
      Afterwards I loaded both controllers with firmware 3.1.5 and repeated the missions. Both controllers flew the missions very accurate, without twitching or other unwanted behaviour. Furthermore they both seem to fly much more stable in Manual, Loiter and Auto mode. Not as nervous as with 3.2rc2 firmware.
      Best regards,
      Jan Willem
      3702498448?profile=original
      • Hi,
        could anybody solve this issue with our copters? That'd be nice if this issue could be fixed in RC3.
        If further test flights are necessary to collect more log datas, just tell me and I'll try to provide the flights.
        Thanks in advance.
        Adrian
        • I forgot to tell another maybe important fact.
          I upgraded from 3.1.5, so many parameters came from 3.1.5.
          Maybe some tuning problem in nav??? (The strange for me is that RTW works without this issue, but uses the same nav PIDs?)
          Best regards
          Adrian
