ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • i just tried compiling, and I got a verification error:
    I posted here so that if others run in to the issue, it's more easily digestible when found on a search engine.
    https://github.com/diydrones/ardupilot/issues/1157
    I believe, based on https://github.com/MegaPirateNG/ardupilot-mpng/issues/134, that it may be that my APM 2.6 has run out of memory.
    Can anyone else confirm?
    • confirmed. I removed everything from AP_Motors_Quad.cpp that I didn't need.... and it flashed.
      What do we do?
      What do we decide what features go forward with the APM?
      How do we restrict certain features to the APM or other platforms?
      • could it be that I have too many logs left on my APM?
  • Guys, has Mission Planner caught up with the flight modes available in 3.2 yet ?
    The reason I ask is that Hybrid mode is not being reported correctly in the flight status screen.
    Martin
  • Motor Mixing in VTail Quad configuration has rear-motors backwards.
    We want the motor layout to mimic that of the X-Quad, however, in order to get it to fly, you need to swap the rear motors (2 and 4).
    Otherwise it just yaws like crazy.
    • I opened a pull requset for this: https://github.com/diydrones/ardupilot/pull/1148
      I think the original swap done by whomever merged in the code was maybe due to thinking the tail was an A rather than a V? idk.
      the V is inverted motors. :-)
      A is normal, upright motors - which is what the VTail mixing would have worked with prior to this change.
      So.. should we also have an ATail mixing?
        NullVox,
             That'll be my fault for messing it up as part of the merge.  I'll merge your pull request after we get through the AVC competition this weekend.
        • It's all good. It took me a while to realize you may have been think A-Shaped VTail (rather than a V-Shaped VTail), like what Flite Test made a video and sells parts for.
          In my PR, I've added support for both types of Tails. :-)
  • Success using DO_SET_SERVO and DO_DIGICAM_CONTROL using 3.2
    I've been tearing my hair out trying to get a waypoint sequence (see below) to work for doing panorama photography on my new PixHawk and Hexacopter build. Turns out there's something missing/broken in ArduCopter 3.1.1 through 3.1.5 for PixHawk because it skips right over the DO_SET_SERVO and DO_DIGICAM_CONTROL commands and only executes the WAYPOINT commands. When I tried 3.2 it worked just fine! #.2 looks very promissing for doing some high altitude, high resolution panoramas, I'm looking forward to the final release.
    A tabletop waypoint test of pitch control of the camera gimbal (using RC9 as a PWM ) and shutter release (using RC11 as a relay) works fine in ArduCopter 3.2 using the following sequence on my kitchen table:
    WAYPOINT 0,0,0, no wait
    DO_SET_SERVO 9, 1500
    WAYPOINT 0,0,0, 2 second wait (waiting for gimbal to complete pitch move)
    DO_DIGICAM_CONTROL
    The same sequence using the same configuration options did not work on 3.1.5, 3.1.4, 3.1.2 or 3.1.1.! At that point I gave up trying to go backwards to older versions since WAYPOINT 0,0,0 seemed to be pointing it to somewhere in the South Atlantic.
