Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Ah that makes sense, cheers Randy. Lol I only realised a few days ago and bolted it on - oh well.
Thank you to you and team for all the great work on this project!
Still works on Pixhawk, must just impact APM.
I did some tests with 3.2 rc5 today and I had few crashes )-:
Copter is SKy hero x8 with pixhawk. It was flying perfectly, no problems with 3.1.5.
Installed 3.2 rc5, calibrated compass and accelerometer and went out do do some tests.
The first tests were take off in stabilize, then flying in alt-hold, loiter, (with and without EKF) and RTL. No problems so far.
Then I decided to try short auto mission with automatic take-off and few spline way points. At the take off copter immediately flipped on its nose, one prop and gps mast got broken.
After repair I tried another take off in stabilize, everything OK so far, switched to alt-hold and after few seconds copter started do drift and crashed. There was nothing I could do with RC.
I had a quick look on log files, there were errors like:
Test: PM = WARN - 1 slow loop lines found, max 7.53% on line 9650
in both logs.
I have no idea what went wrong. Any clue about the possible reason for crashes (hardware, setup, ...) would be highly appreciated.
Regards, Jure
59.log
60.log
Well, the first crash at the take off can be probably related to the warning #1. It seems that the problem with full throttle is there also with the take off in auto.
What is still a mystery is a crash in alt-hold, perhaps some bad vibrations?
3.2-rc5:
RCMAP_YAW, RCMAP_THROTTLE, RCMAP_ROLL and RCMAP_PITCH can be changed and save.
However they are not functional any more.
Not sure why.
Henri,
Thanks for the report. I think it's a reporting issue. So the roll, pitch, yaw and throttle controls are properly remapped internally but the output that we see in the mission planner's Radio Calibration screen doesn't show the change. I've made a change so rcmap is reflected in the message arducopter sends the mission planner and it'll go out with -rc6.
Update: unfortunately the change I mentioned above wasn't compatible with plane so I've had to revert it. I think we will have to handle this in the documentation or ask MichaelO to modify the GCS to flip around where the green bars appear based on the RCMAP parameters.
Same seems for ResetToArmedYaw, set @ CH7. Can be changed and saved, but it doesn´t work. Maybe someone else can try it. Btw. checked the logs, no ERRORs reported.
Regards
I Have a technical question .. If you arm on top of a hill, baro sets altitude at zero .. you take off and fly to say 40ft then fly down into the valley below.. so now your baro altitude goes minus 40ft what would happen ? Would the copter think it landed, what would happen to the throttle ..or say you wanted to land at a lower altitude than you took off from ? these are scenarios I could see me doing as I live in very hilly country side.
cheers Reuben
This is a little off-topic question but is it possible you devs implement a way to set current position as home via a switch?
Thanks guys for all the hard work, waiting for rc5 so I can fly my TBS Discovery without any worry
you can do-set-home via radio telemetry
http://copter.ardupilot.com/wiki/mission-command-list/#Do-Set-Home
