Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Thanks for the analysis was fearing it was something like that but wasn't sure how to check for the landed condition :(
At least the crash wasn't pilot error for me this time :)
Would it be possible to get the pixhawk to use both gps to get a better gps position say halve way between the two
Just a thought
Stuart
Longer term Paul Riseborough (EKF creator) will make the selection of the GPS a little more complicated. I'm not sure if he will make it a weighted average (like the accelerometers) or just pick the one that agrees more with all the other data.
Hi Stuart,
I think the current management is the best as the controller is currently using the GPS giving the best accuracy and stability of position.
Doing a mix of both GPS modules would just degrade the quality of the best one.
Julien
Randy,
Thanks a lot, crystal clear, great job.
Attached video of my mini quad with mini APM and RC6
Best Regards
RB
Hi, yesterday I was flying with my hexacopter and firmware 3.2-RC5 after Autotune. The result was very good. In all flight modes I had a great performance. I tested Stabi, AltHold, Loiter, PosHold, Sports and RTL. My FC is a 3DR APM 2.52.
Thanks to all for this great wort!!!
Hi all,
I am having some problems with AltHold/PosHold (Ac3.2rc6). The copter loses altitude while moving:
Anything else I could test?
Thanks in advance!
Thorsten
Thorsten,
There shouldn't be any difference in AltHold performance but if you can provide a dataflash log file I'll have a look. Ideally similar flights with AC3.1.5 and AC3.2 would be best but I understand that could be difficult.
There's two possibilties I can think of:
1. Baro disturbances, aka flattening out after fast forward flight. This issue has existed since 2.9.1 but it gets brought up again and again. We will have a look at it again for AC3.3 but it's an aerodynamic effect so could be hard to resolve in software.
2. angle boost is not being applied. This shows up in the CTUN message's AngBst column.
Randy,
attached you find a log of a new flight showing the effect with THR_ALT_P = 3. It seems to be Baro disturbances. If you need more logs with special settings to parameters please let me know.
As the copter is descending several meters AltHold is not really usable with this copter/settings. It would be great if there would be some solution.
Thanks for looking into this!
Thorsten
Speed_vs_Altitude.bin
Randy,
thanks! It is a long endurance copter with up to 50 min flight time with one camera. So maybe not a typical system. I'll prepare a (3.2) log with a new flight tomorrow and I will test it with different payloads.
I'll also make a test with 3.1.5 at the weekend.
Setting THR_ALT_P to 3 has almost no effect. Anything else you want to see tested?
Best regards,
Thorsten
