ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Je Je I'm not the only anxious ;)
  • @Randy
    Hi, How far are we from the stable release of this code? Cheers, Mike
      When we stop finding issues!
      • Ha ha good answer! ;-)
    • +2 :)
    • +1
  • This reply was deleted.
    • I ordered this one but have not been able to find out if it shipped after 5 days of ordering. Marco mentioned this place and that if you mention what controller you use they will send it flashed ready to work with it. Can't wait to get it... if it ever ships :[
      http://www.virtualrobotix.it/index.php/en/shop/accessories/gps-ublo...
    • From the pictures it looks like it's neo 7 have received it?
  • Randy,
    Thanks for the clues on the FS_THR_VALUE.
    I'm using a FrSky Taranis adn X8R receiver. My RC3_MIN is 982
    The default FS_THR_VALUE was 975.
    I had to set the FS_THR_VALUE to be 971 to stop the 'check FS_THR_VALUE' warnings. Note that when I set it to be 10 below RC3_MIN (972) I Still received the warning.
    If FS_THR_VALUE must be 11 or more below RC3_IN, perhaps part of the Radio Calibration Routine should automatically set this value or provide a warning if the values are out of a valid range?
  • Hi Randy, I have been flying with APM2.6 &  AC3.2RC5, since it was released and did almost several hundered flights and had never any crash due to firmware ( I had crashes due to my mistakes). Do you still recommend me to upgrade to AC3.2RC7 ?  In 99.9% of my flights, landing was only by the firmware and not myself. Was its only my luck that I had no crash due to firmware ?
