Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
I believe this is only the case when using the EKF, but I am not 100% positive on that. For now, if you leave it disabled, you should be ok.
Shaggee,
There is a very large motor imbalance between the clockwise and counter-clockwise motors. The ch1 motor (front right) is at full speed for much of the flight. An imbalance of perhaps 100 between CW and CCW is ok, but the imbalance here is a bit over 300 between the farthest apart motors (#1:front-right is very high while #4:back-right is very low).
By the end of the logs (perhaps as the battery weakens) two motors are nearly pegged to the top of the range while the other two are alternating hitting the bottom of the range. I think the vehicle simply cannot maintain it's attitude anymore and comes down.
I watched your video, I'm pretty sure that your crash is due to synch problem with your motor esc or bad electric connexion of one motor /esc.
Could you please share your log?
@Jim Johnston,
I was wondering if you could try this modified version of -rc9 to see if it resolves the motor pulsing you've seen on your APM2? Basically I've added back the 4hz filter on the velocity error.
ArduCopter-3.2-rc9-altfilter-APM2Quad <-- APM2 quadcopter
ArduCopter-3.2-rc9-altfilter-APM2Hexa<-- APM2 hexacopter
In case anyone is interested, this is the exact branch I'm using for this version.
Sorry, again slightly bad behaviour for me to release interim versions between the release candidates but I'm not quite ready with -rc10 and also I don't want to make this change for all immediately in case it doesn't fix the problem.
Randy,
A few things for you to review when you have a minute.
Dropbox URL contains logs of this evening's flight. https://www.dropbox.com/sh/7yzlcep21iaaj8e/AACLULPwY6eYINoAMJsvkEGp...
Running into an issue with Y6 yawing counter-clockwise. Seems I can't tune it out.
Also noticing the copter is loosing power and touching down. Not sure what to make of that.
Log File C:/Users/Doug Walmsley/AppData/Local/Temp/tmpF6F7.tmp.log
Size (kb) 1676.1474609375
No of lines 23059
Duration 0:03:35
Vehicletype ArduCopter
Firmware Version V3.2-rc9
Firmware Hash 75a1e46d
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = UNKNOWN - No ATUN log data
Test: Balance/Twist = GOOD -
Test: Brownout = GOOD -
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: CRASH
Test: GPS = GOOD -
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = FAIL - Avg climb rate -75.02 cm/s for throttle avg 919
Test: VCC = GOOD -
What am I to make of the Thrust information?
Also in the logs are the LEA-6H (GPS 1) and M8Q (GPS 2) information.
Doug,
Thanks for your testing by the way.
Re the GPS, the M8Q seems to be doing better, or at least it has a higher #sats and lower hdop. Both GPSs aren't doing that great in this log though with 9 sats and hdop=1.9 for the MQ8. The positions of the two GPSs are quite similar, they disagree by about 1m at one point but that's not too much really. The MQ8 looks like overall it's reporting slightly less movement than the LEA-6H. Could be it's position on the vehicle or it could be it's settings are a little different. Anyway, the differences are pretty small.
Doug,
Maybe there's a propeller on backwards or the Frame type isn't selected correctly? The RCOUT is not appearing in the dataflash logs. I guess the LOG_BITMASK is missing some values. I plan to recheck the default to make sure it includes everything.
It could also be a low battery contributing to the problems. You can see in the graph below how the throttle out suddenly climbs to 1000 (=100%). At this point the flight controller has to make decisions about what to sacrifice. The general priority is to sacrifice some yaw, then altitude, then the rest of yaw, then roll/pitch.
I'm pretty certain this isn't a firmware issue though.
-Randy
Thanks Randy.
I'm planning to use fresher batteries to see if the battery I used is the issue. All propellers are mounted correctly and I've been reporting that all lower motors have been over heating. The lower motors are measuring around 130-150 F while the upper motors are holding at 85-90 F. So I'm seeing a power loss in lift and wondering if the lower motors are no longer affectively helping to produce lift. I will go back and ensure RCOU is enabled and will share my findings.
Doug,
I had a similar problem with my Y6 trying LiIon cells - lower motors always at ther thrust limit.
I had 14 x 4.7 props on all motors.
I now use 13x4.5 on upper and 14x7 on lower motors, so now they have all nearly the same thrust.
Glad you found it!!!!!!!! Hey what gps were you using?
122
123
124
125
126
of 262 Next
