ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
        • AMP 2.6 using 3.2 rc7 Arducopter Droid Planner 2.6 Beta from
          http://3drobotics.com/2014/06/follow-me-mode/   "using Nexus 7"
          Follow Me works just fine with this setup.
          Now 3.2 rc9 I can't get follow me to work. I do see a new droid Planner which I have not
          updated to yet.
      Thanks Rainer for your feedback.
  • Hi Marco.
    I am unable to use Hybrid Mode / PosHold with my Walkera QR-X350-Pro (APM Copter 3.2).  Loiter works fine, but it does not change into PosHold mode in Mission Planner when I activate it.  Nor does it work flying.  Any idea why this might be?  I noticed a few other people are also experiencing this problem with their QR-X350-Pro.
    If you have any ideas, I would greatly appreciate it.  Thanks again to all you guys for your great work!  ;)
    - BaNe
      I'm sorry but i don't know what firmware is installed on that machine.
      It's possible that we have removed some features.
      • Actually, with the latest firmware from Walkera, Loiter is flying fast now.  But, I am trying to fly a 40 meter circle.  But, I get a partial circle then a corkscrew towards the center.  Any suggestions on the Circle_Rate parameter?  I believe the quad has a version of AC 3.2.  So that's in meters?  Thanks, Brother.
        I found out PosHold doesn't work on my Quad.  But, the new Loiter is fantastic.
  • I did my range finder setup. I have an EZ4 sonar and did the settings according to the online instructions sonar settings for arducopter 3.2. When i lift copter above 20 cm then the readings seem fine. When it goes below that the reading shoot upto 130? And stay there until i lift it up above 20cm. Will this cause it to shoot up when trying to auto land?
    • Pic 1 sonar reading when in land position
      Pic 2 sonar reading when lifted about 20cm
      https://storage.ning.com/topology/rest/1.0/file/get/3702519513?profile=original
      • MR60
        hi,
        the minimum distance the sonar can measure is 20 cm. This is normal.
        • Wont that cause any problems when landing in auto. And thanks for reply
            Definitely the bad sonar alt is not good and I'd expect problems when landing in AltHold or Loiter so we should get to the bottom of the problem.
            While landing in Auto, RTL it should be ok because it doesn't actually use the sonar for that (it just sets a target speed).
