Warning #1: PX4/Pixhawk users upgrading from AC3.1.5 (or earlier) may need to re-do their compass and accelerometer calibration because AC3.2 also uses the backup compass and accels. Pre-arm checks have been added to ensure this has been done.
Warning #2: on the APM2.x the logs must be downloaded using MAVlink instead of the terminal.
AC3.2-rc14 is now available for BetaTesters through the mission planner’s Beta Firmwares link. The full release notes can be found in ReleaseNotes.txt and changes from -rc13 can be seen below.
It’s a big release with “the onion” restructure and a bunch of new features (including these 57 closed items) so we need to re-test almost everything including all flight modes, all mission commands and all the new features. Marco and I will be maintaining (and adding to) this testing list. Issues reported will first be checked by Jonathan, Marco and I and then confirmed bugs/issues will be put on the github issues list (and then hopefully fixed).
Thanks especially to the beta testers who put their copters at risk testing each release. Enjoy!
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
Wesley,
I had a look at your logs and it also looks like a brown-out. In this log though we're slightly lucky in that we can clearly see the main battery voltage dropping to 8V in the last 0.5sec of the log. Obviously it's not a "lucky" situation that the vehicle crashed but "lucky" in that it points pretty conclusively towards the cause of the problem (a power issue). Can you describe how the board is powered?
Happened to me last week, flying around in Loiter (AC3.2RC12), next thing copter lost all power (motors stopped spinning) and fell to the ground. All connectors checked out, etc. Auto analysis reports looks exactly like yours incl the VCC warning.
Same thing happened to me, crash after motors just stopped, with the logs truncated. Almost identical to the two above.
http://ardupilot.com/forum/viewtopic.php?f=25&t=8769
Graham,
Looks like that report was while running AC3.1.5. It does appear to be a brown-out, although we can't see any evidence to prove it except that the logs suddenly stop. The board voltage is relatively stable between 5.12 ~ 5.26 volts. A 0.15V variation is fairly common. The battery voltage and throttle out are all pretty normal.
My guess is that at times we're stressing the battery, ESC or powermodule with requests they can't handle and the flight controller isn't getting the 5V it needs. I would be overjoyed if someone was able to reproduce the problem on a bench so we could investigate it more and see if there's something in the firmware that we could do to reduce the pressure. I think, for example, it should be possible on these copters to make the flight controller black out by flipping the propellers over (and rotate them one position) and then really stress the system with fast increases in throttle. This could be done in stabilize mode using some transmitter programming to make the throttle go between 0 and maximum at the flick of a switch. On the otherhand if the pixhawk never blacked out that would point towards the problem not being a power issue (i.e. points back at the firmware).
Rana,
On the surface at least, it looks like a brown-out. The logs suddenly stop 2.1 seconds after entering Guided mode when the vehicle is about 3m in the air. A catastrophic software bug might also look the same but there's no evidence of that. All the navigation values (i.e. NTUN messages) look sensible.
Is this a custom version of the firmware? The version name is a little different and the rate of the CURR message is higher than I would expect.
Today again, I tried to simulate the same condition and had again a test flight with AC3.2_RC12 with APM2.6. I took off in Loiter and at 3mt altitude, using latest DroidPlanner 2, while, the quad was in loitering, set follow-me from the phone.
Within a second, of touching follow-me, all motors were stopped and the quad fell like a rock. Attaching the flash and telemetry logs. So there seems a nasty s/w bug in the code which at least me able to demonstrate.
In telemetry log, Quad arms at 73% of the telemetry log file.
Auto analysis report:
Log File C:/Users/Narpat/Desktop/Telemetry Logs, Videos, EEPROM & Flash uploads/Telemetry Logs/AC3.2_RC12, APM2,6 Crash (2014-10-26 17-29-22)/2014-10-26 17-32-19.log
Size (kb) 352.9453125
No of lines 5098
Duration 0:01:24
Vehicletype ArduCopter
Firmware Version V3.2_RC12
Firmware Hash
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = UNKNOWN - No ATUN log data
Test: Balance/Twist = GOOD -
Test: Brownout = FAIL - Truncated Log? Ends while armed at altitude 3.91m
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = GOOD -
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = WARN - VCC min/max diff 4.898v, should be <0.3v
2014-10-26 17-32-19.bin
Hi Randy, I am attaching the f/w hex file, EEPROM file, read from the Mega2560, for your analysis.
FLASH2560.bin
2014-10-26 17-29-22.tlog
EEPROM2560.bin
Hi Randy,
Yes, this was a compiled version, since at the time when I tested RC12, it was not available in Mission planner.
In this version, Mount: Disable, Cam_Trig: Disabled, Pos_Hold: Disabled, Frame: Quad, Fensing: Disabled, Loging: Enabled, Autotune: Enabled.
Compiled AC3.2RC12 was uploaded using Arduino-Ardupilot 1.03.
On CURR message, I can't say anything, I used parameters of RC5, with which I have no failure since months when It was out.
To avoid any issues, why don't you in the future get the firmware from:
http://firmware.diydrones.com/Copter/latest/
Even if the firmware is reported as released and not in mission planner, you can always get it from there.
Just download the correct platform version and load the firmware file in mission planner using the custom firmware option.
yesterday i loaded the rc13 to my new Tarot 650 with 6S 380kv 15x5,5 Props and RTFhawk with M8GPS from csg.
The first flight test was ok. Smooth flight in Stablize but toilet bowling in PosHold. After the flight with about 35% throttle i have set the Throttle MId parameter to 398 and have done a compass mot. Then today i have done three flights. First flight i have done a autotune witch you can see in Log 1 and there are a lot of EKF errors.
After the Autotune the Tatot is swinging/vibrating extreme when i switch to poshod. (see log 2 and 3)
So i think the Autotune parameters are not ok.
The second stange thing is the battery fail safe you ca see in the logs. In the params all FS functions are disabled.
Hope you can find something out in the log about auotune / vibrations and BAT FS.
Regards
Sven
Tarot_650_Autotune.zip
Tarotnach autotune.param
