ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • 3701777759?profile=originalHello
    Does someone know how to control two landing gear retract servo from Pixhawk...I know I have to power servos from bec, but where signal goes...Aux out does not seams to work ..
    I am a bit lost in all this connections...
    can I use some of MNT_MODE parameter ?
    https://github.com/diydrones/ardupilot/issues/1123
    • this suggestion from support forum somehow does not work for me:
      " @dmurray14.....The pixhawk (IIRC) doesn't support RC passthru, but you can "hack" it to work with the camera gimbal screen assuming you aren't using that already. Plug your leg servo into RC9 on the Pixhawk (labeled AUX1) and go into the camera gimbal config screen and set RC9 to be tilt, for instance. Make sure to uncheck stabilize and then set the limits as required and set the input channel to whatever you want the trigger to be on your TX
      3DR Support
      I think you can try to follow @dmurray14 suggestion but instead of tilt, use the roll, Iris is preconfigured only to control the tilt so roll could be used for the retractable landing gear
      The red wire of the gimbal connection is connected to Pixhawk's AUX OUT 2 (RC10) so you could take this red wire and split the ground (brown wire)."...????
        You need to also power the servos on PH with a BEC on the servo rail
      • heres what I did. as I also have lights hooked up to the gear switch. make sure you change servo limit to 1900 in mission planner under gimbal
        https://storage.ning.com/topology/rest/1.0/file/get/3702658341?profile=original
  • I've been testing my quadcopter with the latest beta release of 3.2. I uploaded a simple mission where the copter was supposed to fly to 10 m an loiter. (I had put a small Canon point-n-shoot camera on it as well.)  For some reason the copter decided to fly to nearly 120-130 m (~400 ft) after I attempted to Land. Then it oscillated from 120 m to 25 m a few times then finally got close enough to the ground to cut power to land. I didn't see any obvious error conditions. It kept centered over the original takeoff coordinates and kept the same yaw orientation thoughout the flight.
    Has anybody seen this problem?  (I attached logs and the altitude profile.)
    Also, the wpalt values seems to be missing from the logs.
    2014-07-06 21-05-37-pogo-flight.log
    • Was this the first time with the camera?  Is the camera equipped with Wi-Fi?  I only ask as I've read that GoPro cameras with Wi-Fi can interfer with radio reception.  Just curious to help identify your problem.  When you fly without it, did the multicopter repeat the flight characteristics you observed?
      • I just ran another test and it flies fine without the camera. I had also noticed that the HDOP was a little higher than normal. (I usually like it below 2, but it was above 3 for some reason. I flew in the early evening so maybe the satellite geometry was non-optimal as well.)
        • Another experiment I'll try will be to change the INAV_TC_Z parameter to 0 to solely use the barometer to see if it was accelerometer/vibration related.
      • I was using a little Nikon CoolPix S8200 camera zip tied to the frame as a poor man's video platform. It doesn't have any wireless communication capabilities. It may have something to do with the additional weight. The copter seemed to pull it fine and level out without a problem. It worked fine before without the camera.
  • I make a simple quad copter by ArduCopter 3.2RC2 on P4FMU only.  The receiver is FrSky TFR4-B.
    I set ARMING_CHEK to 0 (zero) to disable pre arming check to escape safety button function.
    The armed and disarmed function are working by observation of Mission Planner.
    However, the actual out put of CH3 is not activated at all.
    I think this is not normal but just give a try to avoid PX4FMU to garbage:-(
    Any idea?
