ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
  • Whats actually stoping this coming out of beta, If i understand correctly it is to do with bugs?
    Really want the new hybrid/poshold mode!
    Are there still bugs?
      Luke,
      There are a few issues still:
      • INAV/EKF check's are perhaps too strict meaning it's switching to LAND mode even though inertial nav or the extended kalman filter is still functioning properly.
      • Traditional Helicopter has some enhancements that need to go in.
      There are also some more issues still on the to-do list for AC3.2 but I think they will instead slip to AC3.3.
      • I'm using APM2.6 with rc5 and the more aggressive I fly, the more I see it going into land mode. I also see the EKF alert in MP. Where can I relax those checks? Also the RTL is still yawing home before rising. Very jarring when you are doing FPV and running away from home ;-)
  • Hi Randy and Team,
    Any idea what causing the CW motors are spinning faster than CCW that causing Extreme Yaw on take off?
    Complete problem describe here : DIYDrones Forum and APM Forum
    3691144951?profile=original
  • i am unable to download the log on rc5 too
      Ibrahim,
           You're using the download via mavlink as described here?  Which board and frame are you using?
           Txs for the report.
      • I am using apm 2.6 board on a quadcopter.
        I was able to download the log on 3.1.5.  After loading 3.2 rc5 fw on terminal screen when i click the connect button it give me some words like calibrating etc etc. When i click log download button i don't see numbers on left.
          Ibrahim,
          Ok, so the cli was removed for the APM2 to free up flash space.  If you follow the directions for downloading via MAVLink it should work.
          I'll add a note in the main part of this discussion above because this has caught a number of people.
  • APM 3.2-rc5: Didn't had the courage to try a mission.
    Stabilize, Alt hold, Loiter: Ok.
    Unable to download log from apm using USB cable. (with -rc5)?
    So limits a lot possible understanding of what is happening..
    Henri
      Henri,
           Which board (i.e. APM2) and frame type (i.e. Quad) re you using?  It's working for me on an APM2.6 running quad software.
