ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • Thanks for the analysis was fearing it was something like that but wasn't sure how to check for the landed condition :(
        At least the crash wasn't pilot error for me this time :)
  • Hi pixhawk with twin gps
    Would it be possible to get the pixhawk to use both gps to get a better gps position say halve way between the two
    Just a thought
    Stuart
      Longer term Paul Riseborough (EKF creator) will make the selection of the GPS a little more complicated.  I'm not sure if he will make it a weighted average (like the accelerometers) or just pick the one that agrees more with all the other data.
    • Hi Stuart,
      I think the current management is the best as the controller is currently using the GPS giving the best accuracy and stability of position.
      Doing a mix of both GPS modules would just degrade the quality of the best one.
      Julien
  • Randy,
    Thanks a lot, crystal clear, great job.
    Attached video of my mini quad with mini APM and RC6
    Best Regards
    RB
    • Hi, yesterday I was flying with my hexacopter and firmware 3.2-RC5 after Autotune. The result was very good. In all flight modes I had a great performance. I tested Stabi, AltHold, Loiter, PosHold, Sports and RTL. My FC is a 3DR APM 2.52.
      Thanks to all for this great wort!!!
  • T3
    Hi all,
    I am having some problems with AltHold/PosHold (Ac3.2rc6). The copter loses altitude while moving:
    3701820478?profile=original I am not sure if this is related to 3.2 and/or rc6. However, it is the first time that it is that dramatic. So I think I have to play with "Altitude Hold P" (THR_ALT_P).
    Anything else I could test?
    Thanks in advance!
    Thorsten
      Thorsten,
      There shouldn't be any difference in AltHold performance but if you can provide a dataflash log file I'll have a look.  Ideally similar flights with AC3.1.5 and AC3.2 would be best but I understand that could be difficult.
      There's two possibilties I can think of:
          1. Baro disturbances, aka flattening out after fast forward flight.  This issue has existed since 2.9.1 but it gets brought up again and again.  We will have a look at it again for AC3.3 but it's an aerodynamic effect so could be hard to resolve in software.
          2. angle boost is not being applied.  This shows up in the CTUN message's AngBst column.
      • T3
        Randy,
        attached you find a log of a new flight showing the effect with THR_ALT_P = 3. It seems to be Baro disturbances. If you need more logs with special settings to parameters please let me know.
        As the copter is descending several meters AltHold is not really usable with this copter/settings. It would be great if there would be some solution.
        Thanks for looking into this!
        Thorsten
        Speed_vs_Altitude.bin
        https://storage.ning.com/topology/rest/1.0/file/get/3702665688?profile=original
      • T3
        Randy,
        thanks! It is a long endurance copter with up to 50 min flight time with one camera. So maybe not a typical system. I'll prepare a (3.2) log with a new flight tomorrow and I will test it with different payloads.
        I'll also make a test with 3.1.5 at the weekend.
        Setting THR_ALT_P to 3 has almost no effect. Anything else you want to see tested?
        Best regards,
        Thorsten
