ArduCopter-3.2 beta testing
Changes from 3.2-rc13
1) Safety Features:
2) Bug fixes:
      • I had same issue with disarming in PosHold mode. Unable to disarm after landing (probably I have landed on another altitude), but switching to stabilize helps to shutdown.
  • I use Pixhawk with external compass, and caught one bug (latest 3.2 rc7):
    1. Power copter in upside down position (I have battery at bottom, so I rotate to connect it)
    2. Wait for melody
    3. Rotate it back into normal position
    Now, I can't arm ... get "Alt disparity" warning. But, if I take copter and "wave" it, barometer becomes fine and arming fine.
      Yes, I agree with Marco that it's not a bug.
      The "Alt disparity" is a check that the inertial navigation and barometer are in sync.  They can take a while to sync up after starting the vehicle and it'll probably take longer if the vehicle is flipped over.  I suspect that waving the vehicle didn't help but rather it was just the time spent waving it that allowed the two to converge.  I'll update the pre-arm checks wiki page with the new checks added in AC3.2.
      • Agree, this is not a bug, this is feature. After powering and rotating back I can wait up to 2-3 minutes and nothing happens, just yellow light blinking. But, if I take copter and wave it - immediately light becomes green and I can arm and fly without any troubles.
      I don't think it's a bug, you should never connect the battery with the drone in that position, in general it's a rule.
      During the initial phase the drone must remain motionless, and not upside down, for a few seconds after you connect the battery connector.
  • If I turn copter around itself, it doesn't keep position. Doesn't use compass for this? Why?
    https://www.youtube.com/watch?v=PCgIoOujgqQ&list=UUJNbqyTM27_bU...
      Are you using version AC3.2 or AC3.1.5?  AC3.2 does a better job of holding position when rotated like this.
      The reason that it doesn't hold position perfectly is because there are multiple things that make it drift that work on different axis of the vehicle.  This includes wind, the vehicle's COG can also be slightly off causing a drift in one direction, there are also accelerometer biases that can make it think it's moving in another direction.  When the vehicle is still and not turning, we build up a single set of 3D corrections that account for all these disturbances but when the vehicle is turned, some of the disturbances rotate with the vehicle (like accel biases) but some do not (like wind).  It takes a short amount of time for the corrections to build up again (using the GPS) to counter the new combination of wind, cog, biases.
      • Thanks for answer. My english is poor. :( I use AC3.2 RC7. Position holding is very good.
        I talk about direction. Why not keep direction? Uses only gyro for yaw axis?
          ReM,
          Ah, it's designed to work that way.  If it's heading is yanked more than 10degrees from the target it drags the target around.  I think we thought it would be safer this way because it won't whip back around to it's previous heading once yaw control is restored.
          P.S. Your english is totally fine.
    • What mode do you use? Loiter? PosHold? AltHold?
Aug 25
